Blue smoke on cold start - Most likely cause(s)? - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 06-12-2012, 02:31 PM Thread Starter
Excessive blue smoke on cold start - Most likely cause(s)?
Blue smoke from tailpipe on cold start started about one month ago. Engine starts quickly and runs smoothly at all RPM's. The blue smoke will continue until the engine warms up and then goes away under all conditions. There is no blue smoke on a warm engine start even when sitting for as many as 4 hours. Using a mix of Delo Synthetic 5W40 (1/3) and Delo Dino 15W40 (2/3) and just changed oil and filter(Fram/Racor) on Sunday. Oil Pressure is good(75 PSI on start/60 PSI warm). There is no oil residue at the exhaust tailpipe. I am not talking about a little blue smoke, but a significant cloud.
Truck has 121k miles and is pretty much stock as from the factory. Usage is a mix of highway non-towing (60%) and towing a 24' 5th wheel (40%).
I have read a lot of threads here, and there seems to be a number of different root causes(except all are oil related) that result in blue smoke, but most involve a hard start and/or poorly running engine.
Thoughts, questions, comments, opinions?
Thank you.
'05 F350 Lariat Super Duty Crew Cab, 6.0PSD, 4x4, M6HD-W 6 Speed Manual, '17 Arctic Fox 992 TC, AutoEnginuity Scantool
TheCamel is offline
post #2 of 12 (permalink) Old 06-12-2012, 10:42 PM
Cetane Man's Avatar
I would be curious to see what the valve seals look like. Are you adding oil in between oil changes? How much oil?
2006 F-250 6.0 Crew Cab
Red ELC Coolant, Sinister Coolant Filter, CCV Re-route, 6.4 Fuel Banjo Bolts, Fuel Regulator Blue Spring Update, Tint, High Idle Mod, Zoodad Mod, Kenwood, Infinity, Autometer, 4" MBRP Turbo back, No Cat, Sinister EGR valve & Cooler Delete, SCT SF3, Garrett Stage 1 Powermax Turbo, Updated 1 Pc. STC Fitting, Fumoto valve, Updated FORD Oil Cooler, Gates Fleetruner Belt, Blue Anodized Fuel & Oil Caps, HFCM Plug upgrade, DEI Thermal wrap
Cetane Man is offline
post #3 of 12 (permalink) Old 06-12-2012, 11:41 PM Thread Starter
No oil added between changes. I got 13 quarts out when I changed the oil this past weekend. That was going 11 months since the last O&F change. The truck is not a daily driver.
TheCamel is offline
post #4 of 12 (permalink) Old 06-12-2012, 11:57 PM
Term3's Avatar
Blue smoke is burning oil and it doesn't take much to do it. I'd look at the turbo seals first since it goes away when the engine is hot.
Term3 is offline
post #5 of 12 (permalink) Old 06-14-2012, 12:51 PM Thread Starter
Thank you, after researching the turbo seal, I think that is the most likely cause. I have an Autoenginuity PC03 scan tool that should be here today or tomorrow. It likely won't identify a center seal leak in the turbo, but should be able to diagnose if the injectors could be at fault.
TheCamel is offline
post #6 of 12 (permalink) Old 06-15-2012, 04:26 PM Thread Starter
P0299 Code
Scanner arrived today, and it indicates a P0299 DTC. Does not trigger the CEL, but shows an MIL "pending". I have a Ford extended warranty that is good until next April, so have an appointment at the dealer for next Tuesday. I have a recommendation from another tech (not at that dealership) on the Ford dealer diesel tech that says he is excellent.
TheCamel is offline
post #7 of 12 (permalink) Old 06-17-2012, 03:31 PM
nitrogen's Avatar
assuming it is oil, if you are not adding between oil changes, it is not enough to make it worth spending 1 penny fixing. you could try running the "archoil/evergreen" fuel and oil additives. they seem to improve nearly every 6.0 that they have been tried in.
nitrogen is offline
post #8 of 12 (permalink) Old 06-18-2012, 11:33 AM
pennery's Avatar
I have had the cloud of Blue smoke on start up for a while now. Hasn'
t seem to affected anything and goes away when the truck warms up. My truck has close to 300Km on it though..
2003 F350, 6.0L Lariat 267,000kms, Stock except for the Pioneer in dash Nav unit with Back-up Camera... STOLEN May 16th, 2011.
Still looking for her replacement **** Got my truck back from the Insurance company.
pennery is offline
post #9 of 12 (permalink) Old 06-20-2012, 07:24 PM
FICM
My blue smoke issue cleared up after repairing the FICM. It's cheap to do and well worth the effort.
BLK-PRL is offline
post #10 of 12 (permalink) Old 06-22-2012, 01:49 PM Thread Starter
The Rest of the Story
The root cause of the blue smoke on cold start in this situation was contaminated fuel. Most likely from a fuel up, but since I had used 3 different locations since this started, it can't be pinpointed. Had two injectors clogged, but when everything was cleaned up, they "came back to life". Lesson learned........... replace your fuel filters every 3 oil changes.
TheCamel is offline
post #11 of 12 (permalink) Old 06-25-2012, 08:16 AM
How did they get cleaned up? Were they removed and cleaned or did you use an additive? I am dealing with possible clogged injector/injectors and trying to use Hot Shot Secret. Thanks
aminkman is offline
post #12 of 12 (permalink) Old 06-26-2012, 08:07 PM
nitrogen's Avatar
hotshot is an oil additive, camel stated he had a fuel problem. HS won't do a single thing for that couldn't be done better by peeing upwind. HS may help if YOU have an oil side issue, but without more details we can only guess
nitrogen is offline
