Boost Gauge Hookup - Diesel Forum - TheDieselStop.com
Old 05-20-2005, 06:22 PM   #1 (permalink)
mpc
Boost Gauge Hookup
Where is the best place to hook up a mechanical boost gauge pressure tube??
mpc is offline
Old 05-20-2005, 06:35 PM   #2 (permalink)
My Photos: (21)
Re: Boost Gauge Hookup
Easiest place is to T off the MAP. Refer to ITP's Install Sheet
O
6.0 PSD TSB's
02/03 built F350 6L, DRW, 05 Grille , 4" DPPI Exhaust, UltraLites on the A Pillar and Overhead Console, Firestone Bags & Compressor, Hadley Bully Airhorns , 50 Gallon Transfer Flow, Racho 9000's, Leveled 2.5/0, In-Dash PC , XM Commander.
Photos
ozhoo is offline
Old 05-20-2005, 08:18 PM   #3 (permalink)
I drilled/tapped the boost elbow.
Took about 10 min to remove the elbow,drill/tap the elbow and reinstall.
Also NO gauge flutter
2004 F-250 6.0 auto
nummit is offline
Old 05-20-2005, 11:40 PM   #4 (permalink)
Lightningfast01's Avatar
I drilled and tapped the alum elbow going into the engine. Nice steady readings no flutter!
Lightningfast01 is offline
Old 05-21-2005, 08:46 AM   #5 (permalink)
dbennett48's Avatar
I did the same thing. I did it because it was easy to remove and clean before I started the engine. Great results.
Dave [img]/ubbthreads/images/graemlins/smile.gif[/img]
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!!
http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
dbennett48 is offline
Old 05-21-2005, 10:43 AM   #6 (permalink)
My Photos: (28)
Does the boost elbow have a gasket or an O-ring? Just curious when you remove it doesit ruin the gasket if it has one.
2007 GMC 3500 4x4 Dually Duramax/Allison
Sold F350 6.0L TS SRW SWB 4x4 King Ranch FX4
2009 Audi Q7 TDI
2006 VW Jetta TDI
My Truck
My 67 RS/SS Camaro
My Day Job
Armypilot is offline
Old 05-21-2005, 11:43 AM   #7 (permalink)
Army,
Did mine yesterday. Rubber O-Ring embedded into top of intake surface. Just clean the two surfaces and put back together.
2003 F250 SC Lariat FX4 6L; My Truck
AK6LPSD is offline
