Brake light on dash? Help - Diesel Forum - TheDieselStop.com
Old 11-15-2009, 07:04 PM   #1 (permalink)
rfishoutofwater's Avatar
I have an odd issue. The brake light thats on the instrument panel ocassionallty come on and off. It can go for weeks with no issue then all of a sudden it will come on and off. If I hit the steering wheel it goes off. May sound funny but it works. I have not had the chance nor wanted nor had any idea as to where to start. I was thinking it was a connection or a relay but not sure where to look. Is there anything thats in the steering column area that would cause this to do this. I no its vibration as it will do it when hitting bumps or towing a heavy load. Not all the time but it does. Hope this is understandable. my brakes are all new and no issues with them as they function as they should. Any help would be great. This has been going on for the last 6 months or so.
rfishoutofwater is offline
Old 11-16-2009, 07:43 PM   #2 (permalink)
anyone have any thoughts?
Old 11-16-2009, 07:48 PM   #3 (permalink)
Have you checked your brake fluid. If it is low, it will throw a light.
2005 F250 LARIAT CC 4X4 6.0L PARROT CK3200 bluetooth car kit, Shaker 500 system, nice set of train horns, twin viair compressors and 5gal tank, 5" MBRP turbo back, AFE stage II intake, SCT tuner.
1996 F350 AT, IDM and switched ICP mod
1995 F250 SC AT, IDM and switched ICP mod, 6" susp 2" body lifts.
1994.5 F250 SC 5spd 4x4 IDM and ICP mod
bondsman is offline
Old 11-16-2009, 07:50 PM   #4 (permalink)
MikeL46's Avatar
My Photos: (14)
It could be as simple as the switch on the parking brake is right at the edge and vibration makes it come and go.
Or, it could be an ABS issue.
In any case, good luck.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 11-17-2009, 01:09 AM   #5 (permalink)
brake fluid is fine
Old 11-17-2009, 01:10 AM   #6 (permalink)
Mike
i ll check the parking brake.
Old 11-17-2009, 06:28 PM   #7 (permalink)
ok, check the parking brake and all is secure. The other thing is that when this light go on and off it is beeping. It does not stay on it is like a vibration on and off. Like I said earlier if I hit the steering wheel it stops. I am still thinking its a sensor? or a loose connection>?
Old 08-20-2010, 06:43 PM   #8 (permalink)
ok. after all this I have found that it has to be a wire thats been pinched or severed in the steering column as now my turn signals are being effected. tapping the steering wheel when this happens stops it. I have just not had the time to take apart the steering column. any thoughts?
Old 01-14-2011, 01:11 PM   #9 (permalink)
I have the same issue. Did you get this fixed? and how?
2002 X, 4x4, Limited Ultimate, 285 Dueler A/T Revos, Bilstein shocks, Edge mini-spring pack, F-350 4" rear blocks, Street Scene speed grill, Lund trim color bug deflector, Hellwig rear anti-sway bar, tinted front windows, Fram Sure-Drain
neilc88 is offline
