Brand name filters - Diesel Forum - TheDieselStop.com
post #1 of 27 (permalink) Old 03-11-2009, 11:17 AM Thread Starter
jsm
Brand name filters
I was looking at the dieselfilters.com site and the three different brands...Motorcraft, Racor and Prime Guard. Seems that I read that Racor makes motorcraft or is a direct replacement. I have seen Prime Guard filters on tractors and other diesel Motors. There are always plenty of bad reviews of aftermarket parts, Does Anyone have good reviews of Racor or Prime Guard?
09' F350 Dually, CCLB 4x4 Autotrans. Edge insight works when unplugged and replugged.
jsm is offline
post #2 of 27 (permalink) Old 03-11-2009, 11:20 AM
I use my local IH dealer & get Fleetgaurd from them (OEM).
OMC
OMCUSNR is offline
post #3 of 27 (permalink) Old 03-11-2009, 12:12 PM
Strokin' 6.0's Avatar
Can't go wrong with Fleetguard filters; I used them on my Cummins.
If you go to Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks you'll find that the prices are pretty reasonable.
Yes, Racor does make the Motorcraft filters. You can also get the Fram filters, if they have the patent numbers on the bottom of the filters. All the prices are roughly the same, so if you're under warranty, get the OEM stuff and be done with it, so Ford doesn't have an excuse to void your warranty.
Better safe than sorry.
Fred
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch
2012 Ford bed w/Factory Reese hitch option
4.10 TracLok
Dieselsite Coolant Filter
IH Fleetrite ELC
Blue Spring Update
43,956 miles - Replaced 6.0L
54,814 miles - Turbo
94,943 miles - Fan clutch
98,755 miles - FICM
127,057 miles - Aftermarket Alternator
154,120 miles - HPOP & Oil Cooler
168,514 miles - Radiator, water pump, t-stat & hoses
178,810 mles - #7 injector
181,807 miles - A/C Compressor
199,458 miles - Motorcraft Alternator
199,506 miles - FICM
199,521 miles - #1, #4, #8 injectors
Strokin' 6.0 is offline
post #4 of 27 (permalink) Old 03-11-2009, 05:45 PM
FIlters Filters Filters
Personally i wont use ANY FILTER Other then MOTORCRAFT OEM for my truck no sence in taking a chance.... Go to powerstrokehelp.com that guy has a bunch of videos he made and he gose over the reasons for OEM filters vs aftermarket.
06 Lariet FX4 6.0 Disel Fully Loaded Captins chairs Long Bed CREW Cab
tytrophen is offline
post #5 of 27 (permalink) Old 03-11-2009, 05:48 PM
69cj's Avatar
Racors are OEM. They make the oil filters for Motorcraft, IH and Fram Ch9549 and also make the fuel filters. Donaldson makes the air filter for Motorcraft.
69cj is offline
post #6 of 27 (permalink) Old 03-12-2009, 10:04 AM
That's just it - International made the engine, and the Fleetguard is the OEM for International.
OMC
OMCUSNR is offline
post #7 of 27 (permalink) Old 03-12-2009, 01:51 PM
Fram the same as the Motocraft OEM ?
I am having truble with beliving Fram is the same as or made by OEM..... I did an oil change before i left for the river (was in a binde) ford parts was closed so i was not able to pick up a filter so i went and grabed a FRAM, before i put it in i looked at the old OEM and the new FRAM, they were difrent sizes (slightly) ANd the Fram had this Funny plastic ring that i had to insert into the top of the oil filter housing to get the truck to accept the filter. Long storie short it made me very unconftruble on the drive out and when i got to the river i went over to ford and picked up a Motorcraft filter, pulled the funny plastic thing out and tossed the Fram filter in the trash even though it was only 350miles old.. So for ME personlay i would rather spend an extra buck or two and get the OEM and never have to think (maybe this after market filter is scre*in things Up) thats just me... I mean if you got the Cash to buy a 50K truck then why skimp out on filters and oils ? That just dont compute to me...
post #8 of 27 (permalink) Old 03-13-2009, 03:21 PM
dieseldiesel's Avatar
Racor makes the OEM fuel and oil filters for both International/Navistar and Ford.
2004 6.0L Excursion XLT 4X4 (No Engine Mods)
Engine Build Date: 10/13/03
Quad Pod Pillar, Fuel Pres, Trans Temp, EGT, Boost
Sirius Satellite Radio
Draw-Tite Activator Brake Controller
dieseldiesel is offline
post #9 of 27 (permalink) Old 02-24-2010, 11:43 PM
My Photos: (35)
So what is the ruling on the Prime Guard Oil Filter for the Powerstroke?
2000 E350 7.3PSD, Hellwig Stablizer bar, 1.5"spacers from old Correct track OR,140 Lightforce with covers, 5x7 LED's From Truck-lite, extras in the bumper. 4"Aero Turbin and 4" all the way back. 1705 program, Scangauge II,265/75/16E, My Photos
"FAILURE IS NOT AN OPTION"
It riles them to believe
that you perceive
the web they weave
And keep on thinking free
Alaskapsdvan is offline
post #10 of 27 (permalink) Old 02-25-2010, 10:37 AM
i buy my fuel filters off ebay the dealers are asking way to much for a paper cartridge. i saw all the motorcraft videos and matched the 20 dollar fuel filters i purchase threw ebay and they are a exact copy of motor craft they are the same hieght and have the slit on bottom for air to bleed out ive been using them over 7 years without any issues . oil filter i purchase threw pepboys 13 bucks made by puralator i again matched it up with a motor craft filter same hieght and no issues
turbodieselny is offline
post #11 of 27 (permalink) Old 02-25-2010, 03:23 PM
OT
OT's Avatar
A...so far I havent seen any reports on prime gurard o/f. Certainly cost ALOT less. Apparently meet oem specs, but made in china. Im not tempted, but others may be ?
03 F250 XLT SC/SB 4X4 6L (stock) TqS. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
post #12 of 27 (permalink) Old 02-25-2010, 10:28 PM
69cj's Avatar
Sounds like someone switched filters in the boxes. I have a dozen of the Frams on my shelf and they are identical to the M/C's and I/H's to include the patent numbers.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
post #13 of 27 (permalink) Old 02-26-2010, 02:21 AM
LayinHp's Avatar
just did an oilchange and easy as hell but was a 50/50 crap shoot on if it was a ford filter or aftermarket i went with it being a ford one because its an 07 didnt think theyd toss the ford cap was wrong, and it was after hours so couldnt get the proper filtercap ended up a buddy calling in a favour and his friend opened up there UAP store bought there cheap filter and installed it untill i can get the proper cap
couldnt reuse the old filter when unscrewed it seperated from the cap leaveing a gap which would mean unfiltered oil in the engine
if one of these "cheap" filters ever seperated between normal oilchanges how would you know ? you wouldnt so id prefer to spend a couple extra bucks and a filter that fit snug in the oilhousing.
LayinHp is offline
post #14 of 27 (permalink) Old 02-26-2010, 05:18 PM
topgun35's Avatar
I stick with the motorcraft ones i saw the video from powerstrokehelp and makes sense he shows the collapsing filters and how the good aftermarket ones are different heights for a few bucks a will stick with the ford filters.
topgun35 is offline
post #15 of 27 (permalink) Old 02-27-2010, 09:20 AM
Parts Jimmy's Avatar
Watch the video in my signature line and then decide on which filter. Why take a chance on damaging an engine over something as cheap as a oil filter or fuel filter.
7.3 Power Stroke Diesel, 4R100, 4" MBRP Exhaust, Ford AIC, Motorcraft Air Induction System,
DP-Tuned, AIH Deleted, EBPV Deleted, Bellowed Up-Pipes, Dieselsite Coolant Filter, Bilstein 5100 Shocks, Timbren Overloads, Husky Mudflaps, Hella 700FF Driving Lights, Autometer Gauges
Parts Jimmy is offline
