Buying Gold Coolant at the Ford Dealer Parts Dept. - Diesel Forum - TheDieselStop.com
Old 07-28-2009, 08:27 PM   #1 (permalink)
How do I go to my local Ford dealer and buy a gallon of Gold colant for my 2006 6.0? Basically, how do I know they are giving me the right thing?
I'm about to add a coolant filter and I assume that I will need to add some coolant when I'm done.
Thanks for any help,
Brad
2006 F-350 DRW 4X4 PS 6-Spd SC
Brad W is offline
Old 07-28-2009, 08:43 PM   #2 (permalink)
Supporting Member
my03psd's Avatar
Just tell them that you need some Premium Gold Coolant, like this...Parts
I just installed a Dieselsite coolant filter also.Just make sure to use hose clamp pliers when you make your cuts and you'll be fine.I honestly only lost a dime sized drop of coolant.I've read some guys lost a ton and cannot understand why.Found these directions from another site and were a little better than the ones it came with.http://www.dfuser.com/Install%20Guid...filter_kit.pdf Good Luck.
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
Old 07-28-2009, 09:29 PM   #3 (permalink)
Thank you very much; that is just the info I needed.
Brad
Brad W is offline
Old 07-29-2009, 08:20 AM   #4 (permalink)
HeavyAssault's Avatar
My Photos: (6)
Remember to cut the Ford stuff 50/50 with distilled water.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
Old 07-29-2009, 10:01 AM   #5 (permalink)
Thanks! Will do.
Brad
Brad W is offline
