A/C compressor replacement - Diesel Forum - TheDieselStop.com
Old 06-02-2008, 10:24 AM   #1 (permalink)
What am I looking at work wise to replace the compressor on my '06, 6 litre, f-250, 4-wheel drive?
I've taken a look at it, but appears I might need a little help to make it easier.
steve5966 is offline
Old 06-02-2008, 10:43 AM   #2 (permalink)
I just had mine replaced under warranty, they also replaced the accumulator and the oriface tube. There was metal and desicant on the screen.
The write up mentions lowering the coolant level, removing the stator and fan, removing the compressor, transferring clutch and coil to new compressor, setting clutch gap, installing compressor, reinstalling stator and fan, topping off coolant, removing accumulator, installing new accumulator, installing new oriface tube, evacuate and charge system.
I guess you are asking because you are out of warranty now? I was glad to not have to either do the work, or pay for it.
I also used the opportunity to get the latest flash, by mentioning the cold start issue I had 7 month ago. So far so good on the flash.
07 F350 4X4 XL supercab 6.0 Torqshift Lots 'o options, Line X, Isspro EGT, Trans, Voltage in overhead module, airbags, runningboards,mudguards and coolant filter.
My Pictures
DesertDave is offline
Old 06-03-2008, 07:03 PM   #3 (permalink)
Anyone with any other advice on this?
