Cab Removal for Head Stud Install - Diesel Forum - TheDieselStop.com
post #1 of 21 (permalink) Old 12-21-2008, 02:51 PM Thread Starter
Hi everybody, I have a 03 F250 6.0 with the stretched head bolts/ bad gaskets. I have done a lot of research on the topic over the last month and have ordered a majority of all of the parts to repair the blown gaskets. I fully intend to swap the head bolts with the ARP head studs. I saw something today on another forum that made me cringe; someone said that the cab has to come off for the head stud install.
It makes plenty of sense to me that more clearance is required with the head studs as the heads now guide onto the block with the studs going through them. Whereas with the stock head bolts, the heads come in and out any which way is easiest and safest without the cab getting into the way.
I am a confident enough mechanic to get the job done, I was attempting to cut down on costs by avoiding having a shop or dealership do the work. I enjoy working on the truck and I won’t be rushed through the whole process at all, I just lack the tools needed to pull the cab.
Is it completely necessary for the cab to be lifted at all, let alone be removed, in order to install the head studs? Or can this job be completed without having to move the cab at all?
Thank you very much for your time and help and I greatly appreciate whoever responds.
kstoeck is offline
post #2 of 21 (permalink) Old 12-21-2008, 06:20 PM
Remove the cab or remove the motor, your choice. Some have reported doing it without removing the motor or cab but in my opinion your access is so limited that it would be difficult to do a good job. The parts are heavy and the 250ft. lbs. of torque would be hard to apply while standing on your head.
Chillinthemost is offline
post #3 of 21 (permalink) Old 12-22-2008, 02:31 PM
Nope, you don't have to remove the cab but it would make things alot easier.
There's only a few of the studs that will cause you trouble and they are the ones on the back. I think there was 3 on the left side and 1 on the right side that I had issues with. All you need to do is not install those studs into the block, just drop them down into the head and secure so they are about 1/2" from coming out of the bottom and sit the head down. Then you can tighten down the studs into the block.
I would imagine that you could do all of the studs this way if you wanted to as the dowels are going to line everything up anyways.
2004 F-250 King Ranch CrewCab ShortBed 6.0L
kc2kgt is offline
post #4 of 21 (permalink) Old 12-22-2008, 08:11 PM
Parts Jimmy's Avatar
I would pull the cab. Breaking loose the head bolts is difficult with the cab in the way. Re-torquing the new studs would be difficult with the cab in the way.
7.3 Power Stroke Diesel, 4R100, 4" MBRP Exhaust, Ford AIC, Motorcraft Air Induction System,
DP-Tuned, AIH Deleted, EBPV Deleted, Bellowed Up-Pipes, Dieselsite Coolant Filter, Bilstein 5100 Shocks, Timbren Overloads, Husky Mudflaps, Hella 700FF Driving Lights, Autometer Gauges
Parts Jimmy is offline
post #5 of 21 (permalink) Old 12-22-2008, 08:51 PM
expertrider's Avatar
My ARP studs are being installed today. THe cab is up the in the air!
It's actually a whole lot easier if you can do it that way.
If you don't have the big lift, you might be able to get it done with 4 heavy-duty floor jacks and some jack stands. I've heard about some other guys doing it that way. (you'll need some cribbing to get the support for bringing it up high enough)
You really need a little extra clearance to get the back studs installed and tightened properly.
The 245lbs is some serious torque!
The guy doing mine had the cab in the air in about an hour or so.
I helped in advance by disconnecting all the gages, back-up camera, aux tank pump wires, and alarm wiring. All the after-market stuff that would really slow the guy down.
The heads are heavy! It's a lot better to be able to get in there to remove them...
Good luck!!
2005 F250 CC 4X4 Lariet
16k Reese Slider FWH
SCT x3 - only for reading codes,
staying stock for now!
ARP studs installed-and new heads
EGR cooler FIXED for good!
Sneaky pipe!
Coolant Filter
MBRP 4" Turbo Back
Amsoil Bypass Oil Filter w/stainless lines
IssPro A-Pillar gages
Intercooler pipe bracket mod.
Viper remote start alarm
HFCM fuel filter drain mod!
FICM REPAIR MOD
Upfitters w/ high-idle mod
40 gal aux fuel tank
Kenwood DNX7120 Navigation/DVD/iPod/BU Camera/video sytem
Jimmi Jammers (just saved my truck!)
10" flip-down rear LCD screen
18" Wheels from a 2008 F250
Grover Emergency Air Horns
Viair 200psi air system
Bed cover
expertrider is offline
post #6 of 21 (permalink) Old 12-22-2008, 09:02 PM
It can be done as per the workshop manual, with the cab on. Taking the cab off makes things 10 times easier but requires a lift or alot of ingenuity. Once the evaporator case is removed the right side is a breeze. The left side takes a little effort but can be done without hacking anything up.
Gofaster23 is offline
post #7 of 21 (permalink) Old 12-22-2008, 09:13 PM
I thought I was going to have to have head work donw on my Excursion and was concerned about the dealership removing the entire body form the frame. I was assured that on Excursions, they do not pull the body or the motor, so YES it can be done, but it is more difficult...
knightgang is offline
post #8 of 21 (permalink) Old 12-22-2008, 10:02 PM
As per the workshop manual, the living document that dictates in detail on how to perform repairs, outlines the procedure clearly for cylinder head removal on all F-series, Excursions, and E-series. For 2003-2007 F-Series and Excursions within those years. Nowhere does it state to remove the cab in any other those cases. The only time engine removal is required to service the cylinder heads is on an E-series. Starting with the 6.4L in 2008, a cab off procedure was introduced BUT there are cab on versions of all repairs that would require the cab to be off a 2008 and up F-series. Alot of techs choose to remove the cabs on 6.0's, but that's to their discresion. If a dealer tells you that the cab HAS TO COME OFF a 6.0, tell them to read the workshop manual. I can e-mail you the workshop manual section in PDF format if you have questions.
post #9 of 21 (permalink) Old 12-23-2008, 12:44 AM
leros's Avatar
And this is what it looks like when they do it the easy way. Easy access, easy to work on.
Head Gaskets and Studs Photo Gallery by Steve Orel at pbase.com
SteveO
Lemon Lawed back to Ford on 2-25-2010
04 4WD Excursion
leros is offline
post #10 of 21 (permalink) Old 12-23-2008, 03:31 AM Thread Starter
I really appreciate all the replies, it helped quite a bit.
Because of the lack of resources and free cash to spend on a shop I am goign to take a stab at doing it without removing the body or engine. Like a few of you said, its possible to do it this way as the ship manual says so. I'll be starting this friday, right after christmas! Hopefully it goes well and if not I'll be back up here getting your guys' opinions and help.
Thanks again, I really appreciate it!
kstoeck is offline
post #11 of 21 (permalink) Old 12-23-2008, 05:55 AM
Make sure that you have the heads checked for warpage. good luck!
macmaniac1 is offline
post #12 of 21 (permalink) Old 12-23-2008, 07:00 AM
BenBone's Avatar
You deff can do heads without removing the cab...you have to remove just about everything around the motor INCLUDING the heater/ac (hint..hint)
2004 6.0l 4WD Limted Excursion
Road Armor Stealth Bumper with Titan Guard, BFG AT 305's, AR Mojave Teflon's, Tint, Stereo, Remote Start Alarm, Strobes,MBRP Turbo Back T-409 Stainless Steel Exhaust System, AFE Pro Guard 7 Mega System, Edge Insight, Coolant Filter, ARP Studs, Hybrid Turbo, EGR delete
1999 Ford F250 CC LB 4x4 7.3L
DP F5, MBRP 4", AFE Satge II,Garrett Power Max Ball-Bearing Turbo,80hp injectors DM 3 pod, 95 Gallon Transfer/Toolbox Chest, BGF AT 295's, AR Mojave Teflon's,Tint, Road Armor Stealth Base Front Bumper with Lonestar Guard
BenBone is offline
post #13 of 21 (permalink) Old 12-23-2008, 07:02 AM
BenBone's Avatar
x2 GET THEM HEADS CHECKED!!!
BenBone is offline
post #14 of 21 (permalink) Old 01-02-2009, 03:14 AM
You can do the job without removing the cab. I've seen it done in a timely fashion by breaking down the HVAC box on the passenger side and then removing the motor mounts and tilting the engine forward by letting it down with a jack. WHOLE LOT EASIER than removing the cab! Plenty of room to work on the headbolts.
jbrou27 is offline
post #15 of 21 (permalink) Old 01-02-2009, 08:06 AM
When I heard about removing the cab to work on the heads I immediately thought about removing the engine mounts and lowering the engine for enough clearance. To me, this seems like it would be the easiest. however, I'm no tech nor have I done any work on my PSD, so I could be wrong. I'm sure there is someone that has tried this with or without success.
rockcity is offline
