CAC Intake elbow rubber hose - Diesel Forum - TheDieselStop.com
Old 12-18-2009, 11:59 AM   #1 (permalink)
2004 6.0 F350 85,000 miles. The hose connector at the intake elbow and CAC tube is allowing some oil to leak out . Repeated cleaning R&I has not solved the problem. The part number 3C34-6C640-DA is not sold separately by the dealer , but is part of the whole CAC tube assembly for $ 250.
Has anyone found after market supplier or a solution to the leakage. Thanks
kirbybear is offline
Old 12-18-2009, 02:13 PM   #2 (permalink)
I think some reroute the CCV to stop it but honestly if you buy new ones the are just going to saturate and leak again so it is a waste of money. I remember reading a TSB regarding this and the dealer, if I recall, has direction to NOT replace if they are not cracked of split. Just one of those 6.0L things..... Gives it character. If it bugs you that much, I think Banks makes the intake piping with all of their own fittings but with out taking care of the crankcase ventilation the oil will still be there.
2007 F350 XLT 4x4 SC 6.0 PSD No Mods *Traded*
2011 F250 XLT/FX4 4X4 CC 6.7L PSD
johnny87 is offline
Old 12-19-2009, 06:41 AM   #3 (permalink)
Supporting Member
andrewbalser's Avatar
I trashed the CCV vent tube that leads it into the intake. A bought a rubber freeze plug kit at O'Reilly to plug the hole in the bottom of the air intake tube, and now I have a 1" rubber hose that starts at the LH valve cover and hangs down to the front axle like the big rigs. The only downside to doing that is that occasionally I'll also have that drifting oil-scented fog around the cowl of the truck just like the big rigs do when they sit and idle. It's really not noticeable unless the breeze is just right.
2003 RED F-250 Lariat FX4
SuperCab, Short Box, 6.0L, Torqueshift
"1991" Sun-Lite Pop/Up Slide-In Camper
DIY-Coolant Filter
137,000 as of 1/26/2012
3/19/11, Converted to (red) Delo ELC, new bottle & cap, all temps reading good, orig EGR & OIL coolers, probably thanks to the coolant filter, and previously frequently flushed Motorcrap Gold.
Keep on truckin
andrewbalser is offline
Old 12-19-2009, 01:43 PM   #4 (permalink)
I've not seen to much talk of the BD CCV filter which addresses this problem, has anyone else? Has anyone used this filter and where did you mount it if you have a coolant filter on your 2003 and up 6L?
baddna is offline
