CAC Tube Clamp Broken - Diesel Forum - TheDieselStop.com
Old 08-09-2009, 06:30 PM   #1 (permalink)
The CAC tube clamp broke in half today while climbing a hill with my Lance 1181 camper on. It blew the CAC tube off the turbo. Didn't notice where the turbo psi was when this happened. Clamp split in half on the strap. What would cause this? Should I replace the CAC tube also. It made a loud pop noise when it blew off. Hope the turbo is not blown up...?...
2005 F-350 6.0 PSD CC Lariat, Black, Rancho 9000's, Airbags, Edge Insight, Coolant Filter 2005 Lance Max 1181
raiders5 is offline
Old 08-09-2009, 06:57 PM   #2 (permalink)
william_04_X's Avatar
mine has done the same thing.. your turbo and CAC tube are fine.. this usually happens after they have been overtightened..
04 EB X w/03 PSD
william_04_X is offline
Old 08-10-2009, 04:08 PM   #3 (permalink)
ritschner's Avatar
Send a message via AIM to ritschner
It was probably the factory clamp and broke at the rivet hole. I believe there was A TSB on the problem.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB w/cat, Accufab, Edge Platinum/w Evo Trans Tune, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline
