Cam Position Sensor Bad? - Diesel Forum - TheDieselStop.com
Old 10-04-2009, 10:52 AM   #1 (permalink)
I have an 04 with 100K on it. Truck has run great and pulls strong. Recently I've had problems with the engine surging. The RPMs will go high at idle then drop off almost to nothing. At highway speeds I'll get either a surge or drop in RPMs almost like my foot slipped off the pedal or I hit a bump and stomped it down. Sometimes, particularly at low speed, the RPMs will drop and the engine will stall. It's always restarts wtihout any problem. The dealer just put in a new ICP sensor with new connector and that did not fix the problem. I don't want to keep throwing darts at this because it's awfully costly. From reading here, I think I have a bad cam position sensor. Any other thoughts? Thanks.
96 F-250 7.3 L PSD, Super Cab 4x4. 6in Super Lift. 210K and going strong.
2004 F-350 6L 4x4, CC, DRW, 4.10 LS rear, ESOF, Westin Chrome & SS Brush Guard, Reese 16K hitch in bed, Fumoto valve, Air Lift airbags on the rear. OIF 03-04 and 05-07. Our troops are doing a great job. HOOAH!
JimmyRice is offline
Old 10-05-2009, 12:53 AM   #2 (permalink)
Ranger_713's Avatar
Really need to scan it before you throw done the $$ on a new CMP. find someone with a scanner or go to autozone and have it scanned. Good luck..
Values are typical and may vary by 10% depending upon current altitude, accessory operation, engine load, operating time, temperature, and vehicle speed.
Ranger_713 is offline
Old 10-05-2009, 09:40 AM   #3 (permalink)
Good advice and done. I had a P0603 code which I think is from my Super Chip tuner. Cleared the code and that has not returned. But I still have the problem with intermitent high or low RPM and periodic stalling. While I complain about the dealship throwing darts at the problem, I'm doing the same thing. My only clue is this is similar to what my 7.3 L did when the cam position sensor was failing.
Old 10-05-2009, 08:38 PM   #4 (permalink)
Mine is in the shop right now and the tech thinks it is a bad cam position sensor. When he disconnected it, oil drained out of the electrical connection and the interior was coated in engine oil. My truck would run great, then stall and die. It would re-start again... until Saturday! It would idle and then just die. The tech thinks the CPS was shorted out internally due to 1, or both, o-ring failures along the sensor, allowing engine oil to interrupt the signal. The part arrives tomorrow... well see!
2004 F250 CCSB, Lariat, FX4, 6.0PSD, 5SPD TS, AEM Brute Force Intake, OILGUARD bypass kit, MBRP Aluminized Duals, Silverline 6 inch Stainless Tips, Dark Shadow Grey over Black
wmecdoc is offline
Old 10-06-2009, 07:48 AM   #5 (permalink)
Exactly my symptoms except it has not let me sit. When it stalls, it always starts right back. Good luck with your truck.
Old 10-14-2009, 01:02 PM   #6 (permalink)
Did you guys have any CPS specific codes? My truck is randomly stalling (typically off throttle, going downhill or slowing down). The stalling occurs maybe once a week. The idle occasionally fluctuates up and down also, I do not notice this while driving only at idle. I have been thinking it was the harness since I am not getting any codes.
CurlyDE is offline
Old 11-02-2009, 08:13 AM   #7 (permalink)
Sorry for not responding sooner, but NO, I had no codes at all. According to the scanner, everything is just fine. And so you know, though changing the CPS did not turn out to be all that hard, it did not change anything. As our weather here in Colorado gets colder, it seems to me I have no problems if the outside air temp is below 40. If it's above 40, then I start to have the idling and surging problems. Like you, particularly when off the throttle like at a stop light, going down hill, pulling into a parking lot, etc. Hope this helps. Good luck.
Old 05-14-2010, 07:47 PM   #8 (permalink)
ColoradoDoug's Avatar
Any updates???
Curious, what solved the problem?
______________________________________________
'03 Eddie Bauer 4x4 Excursion 6.0 Diesel
CCV mod
Upgraded turbo drain
Blue spring fuel pressure regulator kit
6.4 banjo bolts
v code front springs and modified b code rear springs
Bilsteins
Hellwig rear swaybar
'08 rear diff cover
4x2 liftgate struts
285 Michelin LTX A/T2's
tinted windows
DVD
XM
GPS
ColoradoDoug is offline
Old 05-14-2010, 10:12 PM   #9 (permalink)
ttmech's Avatar
My Photos: (6)
Smile
Bump :>
'04 6.0 F-350 Red, Lariat, CC SB 4x4,power roof & rear slider,K&N ,285-75-16 BFG muds on polished EX wheels, 08 alum. diff cover, SnoPatrol package
ttmech is offline
Old 05-17-2010, 06:28 PM   #10 (permalink)
we need to start an "intermintant surge" club !
mine was getting bad ,, now its gone again...........
Stock 03 250 6.0 SD 2door 4x4 p/u
6.0 June 03 Build Date
92,000 miles
E-017 flash
5" Tail Pipe +Muff Delete , otherwise Stock
AND
2000 f350 7.3 ccab 4x4 , nice BIG truck that lumbers right along. Only 100,000 miles on it.
24hrsparkey is offline
Old 05-17-2010, 10:30 PM   #11 (permalink)
the cheapest things should be tried first, pull your egr and clean it.
pull turbo and clean it.
06 4x4 cc amarillo loaded 20" wheels stock. sold to a lucky man,2000 f350 ex.cab propane 4inch s.s.exht,diablo 80hp chip .
http://www.photoserver.us/is.php?i=143695&img=redo2.jpg
ahurley is offline
