cam sensor failure?? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 03-13-2007, 07:52 PM Thread Starter
My Photos: (9)
A friend of mine just called me and said his 03 6.0 died in traffic. He called the Ford dealer and he said the cps may have went bad. I have never heard of this on a 6.0. He said the tach showed no rpms while turning over the motor. Has anyone had a cps failure and does the tach not show any rpms like a 7.3 when it is bad?
Chris
2014 F-350 CCLB Lariat Ultimate
97 F-350 CCLB BTS built trans and motor w/cryoed block,rods,and Mahle pistons, Hypermax rev kit and inconel valves, 238/100 hybrid injectors, ARP head studs, WOP bottom end girdle and 3" intakes, BTS twin HPOP's and modded H2E. Tuned by Cale@Tyrant Diesel
Truck pics at
Treasurer
<font color="red"> #5 </font>
ytee is offline
post #2 of 5 (permalink) Old 03-13-2007, 09:13 PM
fordmastertech's Avatar
Re: cam sensor failure??
I have yet to replace any CKP or CPS sensors on the 6.0s. I have found many wire chafes that will cause the stalling issue.
FMT
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
post #3 of 5 (permalink) Old 03-13-2007, 10:22 PM
Btravelen's Avatar
BTW, the CPS is really called a CMP. [img]/ubbthreads/images/graemlins/wink.gif[/img]
Take Care
'05 Excursion 6.0L with Air Lifts and Bilsteins, high idle mod., only 'tuner' is in the radio, towing an '00 HR Alumascape 31SKS with a Hensley.
Btravelen is offline
post #4 of 5 (permalink) Old 03-14-2007, 08:35 AM
This engine has both a crank position sensor (CKP) and a cam position sensor (CMP).
As FordMastertech said, I have yet to hear of a failure in either sensor. Oil leaking from the sensor o-rings, yeah, but no failed sensors.
04/04 F250 6.0L Torqshift CC SB FX4
Turbo Cooldown Timer
Diamondback bed cover
Manual idle-up switch
(placing power onto PCM PTO wire)
Fumoto valve
Skweeker is offline
post #5 of 5 (permalink) Old 03-15-2007, 10:35 PM
I had one go bad on my 2004. I was traveling 60 mph and the truck shut off suddenly. I lost power everything and had to coast off the road etc. It would not turn over at all. I was in the middle of nowhere hunting but luckily my cell phone worked and the dealer towed it in and replaced the cam position sensor. That was at around 8k miles and I am now almost 28k and have not had any other issues.
Mark
2004 F-350 FX-4 SRW LB Crew Cab. 35" Goodyear MT/R, Leveling Kit, New Grill, AFE Intake, Tinted Windows, Putco Wheel to Wheel 4" Bars (Love Them and they're rare), Alpine/BostonAcoustic Stereo with 15.2" DVD setup, Spray-in BedLiner, Chrome Emblems, Tekonsha Prodigy Brake Controller
Norcuron is offline
