Can a brake stand launch cause harm? - Diesel Forum - TheDieselStop.com
Old 08-12-2006, 07:23 PM   #1 (permalink)
Just wondering to what extent I am hurting my truck when I stand on the brakes while building boost for quick launch in 2wd? Thaks fellas...
2005 F-350 CC SWB SRW PSD FX4 (decal removed)
Dark Shadow Grey/Medium Flint Leather/captains
SIRIUS
Lariat Luxury with Nifty Xtreme floor mats
Stock 18" rims sporting 35/12.5 Toyo M/Ts
2.5 inch level
Guidepoint
5" MBRP w/kitty
ISSPRO 3 guage set on pillar
SCT from Innovative Diesel
(I run extreme street every day)
1960 Cadillac Series 62 convertible, white paint and top, turqouis leather, 4 1/8 inch white walls, STOCK!
1969 Buick GS convertible, 455 transplant, .40 over, Comp Cams, Edelbrock, TA Performance, TH400,White paint with black interior and black top, original rally wheels.
ZAZBEAM is offline
Old 08-12-2006, 07:30 PM   #2 (permalink)
pajuis's Avatar
My Photos: (6)
Re: Can a brake stand launch cause harm?
You are over working the engine, transmission, driveshaft, engine mounts, and torque converter. You will experience premature wear from these components, but probably your torque converter first. Takes off like a bullet though.
Good luck.
My Ride
2005 F250 XLT CrewCab FX4 Silver Metallic
Reverse Aid Sensors, 10.5" DVD Monitor
6" Fabtech Lift, 1.5" spacer 37" NITTOS on Pro-Comp Wheels,
Airaid Intake, Hypertech 41045 3 Stage in-line PTC,
4" turbo back Diamond Eye exhaust with cat delete,
Crimestopper alarm, perimeter sensor,
remote starter ,turbo timer,
tinted windows ,billet antenna,
billet fuel door and Carbon Fiber taillights.
pajuis is offline
Old 08-13-2006, 01:00 AM   #3 (permalink)
STG
It won't hurt a thing. Really. Please remember to post pictures of the carnage here.
Stan
2005 F250 4X4 SD R/C Power Stroke / Torqshift
Oxford White, Medium Flint 40/20/40 Vinyl, Prefered Equip. Pkg. 600A , 3.73, Limited Slip, XL Decor Pkg., Jeweled Headlamps, Chrome Rear Step Bumper, 9600# GVWR Pkg., Engine Block Heater, Sliding Rear Window, Speed Control / Tilt Wheel, Camper Pkg., FX4 Pkg., Air Conditioning, Forged Aluminum Wheels-17", Tow Command, Telescoping TT Mirrors. Using this vehicle to produce an ambulance voids Ford warranty. Added: Ford factory upfitter switches, Go Industries Rancher Grill Guard (hammered powdercoat), Hella 4000 Rallye lighting (two Euro Beams), SnugTop Super Sport camper shell, Jotto Desk & Escort Redline Radar/Lidar Detector.
STG is offline
Old 08-13-2006, 09:09 AM   #4 (permalink)
My Photos: (38)
Let me tell you a little story about torque braking... Another technician took a stock unit out on a test drive after being royally screwed by the sales department and Ford warranty. During his test drive, he came to a hill in a development area. He torques it up at the bottom of the hill, gets the rear wheels spinning at about 40 mph, and then eases off the brake enough to let the truck roll forward. He then saws the wheel back and forth to make these huge "S" shaped marks in the road - shoulder to shoulder, 100 yards up the hill. It was a constant wheelspin for about 45 seconds. Then, he turns around at the top of the hill, lines up the rear tires to go through the center of the "S", and then spins down them in a straight line. Result, two 100 yard tall dollar signs, about 3/4 tread gone from the rear tires, and cooked rear brakes. The truck was then sold, and the new owner experienced no problems from it.
Another brake torque that ended badly was on an F-150. Stall speed was being checked in the shop, and it was consistantly high from slipping apply components. The technician doing the stall test didn't understand the importance of letting things cool sufficiently, and was only giving the truck about 2 minutes between each test. On the third stall test, the front seal blew, and sprayed transmission fluid out of the bellhousing with enough force to bow the inspection cover. The fluid hits the floor, splashes up onto the catalytic convertors, and flashes. 5 fire extinguishers later, we've got a totalled truck. No grille, no front tires, hole in the hood, broken windshield, etc. The flames went 6 feet above the open hood. Our insurance paid for a new truck....
So, be careful with brake stands, or torque braking. The platform is designed to handle alot - and I mean ALOT - but, the cost of failure is extremely high...
What sig?
GregH is offline
Old 08-13-2006, 10:12 AM   #5 (permalink)
ford_doctor's Avatar
ROFLMAO! Thanx Greg, I needed a good laugh.
ford_doctor is offline
Old 08-13-2006, 11:48 AM   #6 (permalink)
FINE69's Avatar
And you tech's wander why people refer to dealerships as "stealerships" If I caught ANYONE from a stealership doing that in my truck, they would be looking for their teeth! [img]/ubbthreads/images/graemlins/mad.gif[/img]
2009 F350 CCLB Larry-at, 6.4, all the toys....
http://community.webshots.com/user/FineFord
FINE69 is offline
Old 08-13-2006, 03:42 PM   #7 (permalink)
Any pictures of the tire marks?
NFA_Fun is offline
Old 08-13-2006, 07:17 PM   #8 (permalink)
The intelligence level is as visible as the fuel level in the sight glass on the fuel tank. Seriously though man, drop it down in 4wd and for a really good show. As someone else suggested, post pics of the "fun".
2003 Ram 3500, DRW, Cummins HO 48re 4.10...loaded.
i6DZUL is offline
Old 08-14-2006, 01:55 AM   #9 (permalink)
pajuis's Avatar
My Photos: (6)
Greg,
Did you have fun when you did that?
My Ride
pajuis is offline
Old 08-14-2006, 06:17 AM   #10 (permalink)
My Photos: (38)
Hang on.... I don't claim responsibility for either of these incidents...
I was involved in the repair of the first truck.
I did help put the fire out on the second truck.
And, in the dealership's defense, the first truck didn't belong to a customer at the time of the test drive.
Now, there was that 06 mustang - sold unit - that saw a wild test drive during a pre-delivery inspection... but that ma be for another day.
Should I just keep these stories to myself?
What sig?
GregH is offline
Old 08-14-2006, 11:16 AM   #11 (permalink)
No, it's awesome.
'06 F350 CC Red 4X4 Lariat auto
rickeg is offline
Old 08-14-2006, 12:01 PM   #12 (permalink)
pajuis's Avatar
My Photos: (6)
Just giving you a hard time! Keep them coming!
My Ride
pajuis is offline
Old 08-14-2006, 01:55 PM   #13 (permalink)
Tallavana's Avatar
My Photos: (14)
I have a question concerning this post. I drove my friends 6.0 and his was a dog off the line. My 7.3 will litterally burn circles around his. We tried every kind of launch and it will not break the tires free. You can hold the brake and WOT and it just sits there. Once you let off the brake, it starts going but really picks up after the first 30ft or so. I was expecting a little more wow. If you step on it from a dead stop with no brake, its like "yawn" for the first couple of seconds. It has plenty of power while driving, but it definitely has no get up and go. Is this normal or is he having some sort of problem. It is a stock 05. From the previous post, it sounds like a stock 6 has no problem lighting them up.
Light travels faster than sound. This is why some people appear bright until you hear them speak.
2002 F250 Lariat 4x4 Crewcab PSD Shadow Grey/Black
BD X-Monitor, BD Pressure-Loc, SCMT(80),AFE Magnum, 2.5"leveling and 4" block, Bilsteins, Retrax, LineX, Oilguard, MBRP 4" SS, Moto Metal 950 18x9, Toyo A/T 325/60/18, 05 front end w/Harleys, KC 05 light kit w/3 driving lights.
Tallavana is offline
Old 08-14-2006, 02:11 PM   #14 (permalink)
"what extent I am hurting"
The only thing that hurts me is my ego not doing at least 75 feet of duel black marks! [img]/ubbthreads/images/graemlins/smile.gif[/img]
_________________________________
The above information may be speculative, based on misinformation, contain inaccurate data or could be entirely tongue-in-cheek, depending on how litigious the reader may be, how much liquor I've consumed, the degree of stupidity and/or gullibility exhibited by any poster/reader I may respond to. Your mileage may vary. All civil rights reserved. LET'SROLL! 03 F-350 6.0 PSD, XLT, 4x4, CC, auto, skull billet grill, nurf bars, 4" lift, BFG 37x12.50R17, 8.5" Weld Wheels, tonue cover, keyless entry, supersonic alarm, painted bumpers, rear sensing, privacy glass, rear slide window, power everything, drive shaft red, 3.73 gears, camper/tow, block heater, Pro-Guard 7 intake, DPPI exhaust-no cat, Built: 1-13-03 Bought:4-11-03 Flash-06E17 7-5-06 [image] http://photos.thedieselstop.com/show...Truck_350_side [image]
njmjc is offline
Old 08-14-2006, 02:12 PM   #15 (permalink)
This thread brings back an interesting event about 6 months ago. Got stuck behind some #$%ass at a red light. He just sat and sat and acted like his car wouldn't start, then about the time the light changed to yellow, off he went, around the corner. Well, by that time, I was fuming (not really sure why), but I clamped down on the brake, and about the time I saw the cross light turn yellow, I tromped it. I felt my brake peddle slowly going lower and lower, and all of a sudden, the back tires started to spin .... whoo-we, a dually spinning tires no less. About the time I thought I would have to dump boost, the light turned green .... all the way across the intersection - 4 black lines. The dude in his ricer next to me was still sitting there when I had to brake to turn in to a eatery. Don't know that I would do it again, but knowing that I have the oomph kinda boosts one up a notch.
Larry
2006 F350 (Lariat - KR Trim) Crew Cab Dually
6.0L Torque Shift
Tow Command / Tow Boss / Slide In Camper Package
13,000 GVW / 26,000 GCWR
2006 Keystone Everest 345S FW Trailer
2006KR is offline
