Can I remove my turbo without taking off the intake manifold? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 08-18-2011, 08:52 PM Thread Starter
Is it possible to replace the turbo without removing the intake manifold?
The reason I need to know this is because I would rather not have to lift both the intake and the turbo into place at the same time. I had trouble removing the intake manifold before unbolting the turbo. The tab on the back of the intake that bolts to the EGR cooler would not clear the turbo, so after unbolting the turbo I slid the intake manifold out from under it. If I can get the turbo on after the intake is all buttoned up this will make everything a lot easier.
bustedknuckles is offline
post #2 of 5 (permalink) Old 08-18-2011, 10:23 PM
yes you can ...i did it just be prepared for a wrestling match where you get bloody knuckles and curse....I wrestled mine for a couple hours....went inside to decompress....came back out a little later and it came right out....good luck
NGHTRGR is offline
post #3 of 5 (permalink) Old 08-19-2011, 07:02 AM
I have taken my turbo out 3 times and never even considered also taking out the intake manifold. I take out the air intake and the CAC piping. Then I find a comfortable position to lay down on the engine while I take the bolts and clamps off. I don't have a major problem getting it out, I always fight it going back in.
15 F350 Lariat Bronze Fire CC SB 6.7L. New to me at 36200Mi. Krown rustproofing, Armor spray in bedliner.Add 4 LED lights to running boards tied to plugs under frame.
03 XLT F350, CC, Toreador red/silver ,6.0, Auto 4X4, Extang Tonneau. Magnaflow xl turbo back, homemade headlight harness, VR shackles ,harpooned tank, 24" wipers, X-Monitor,FS bypass filter, Energy Suspension sway bar replacement bushings, Sinister coolant filter,HID fogs, scanguage. TRADED IN 114317MI
alex3 is offline
post #4 of 5 (permalink) Old 08-19-2011, 11:26 AM
ryqster's Avatar
AFAIK you need to take of the turbo before you take off the intake manafold...don't ya??? Taking off the intake without first removing the turbo looks like it would be TOUGH.
2005 F450 CC (very red) Fontaine Conversion
6.0 PSD / Torqueshift
BPD Ext Oil Cooler and Remote Filter/EGR cooler
Banks Stuff (CAC, Exhaust)
EDGE CTS
SCT x3 w/Eric's stuff
Stock air box and filter
ScangaugeII
Fleetrite ELC, Rev X
(more improvements in the works
ryqster is offline
post #5 of 5 (permalink) Old 08-19-2011, 11:31 AM
Remove the push in retainer buttons for the wiring harness conduit that is above turbo and wire it up above using wire hooked onto the wiper blade arm.
Remove the exhaust pipe band clamp and then push the pipe back and wedge a 2x2 between pipe and back of intake to keep the pipe back out of way.
Remove the oil feed line and the VGT solenoid wire. Remove the intercooler and in let hoses. Remove the exhaust inlet (Y pipe) band clamp.
Remove the three 10mm hex bolts for turbo. pry up the pass side of turbo as that facilitates the exh inlet pipe freeing itself from turbo as the that piep points at a downward angle. With the pass side of turbo angled up now pry up the driver's side of turbo. You have to lift as the turbo drain tube sticks up into the bottom of turbo and turbo has to be lifted above that so it will slide to pass side to come out.
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 136K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 147K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
2002 F350 CC DRW flatbed (originally pickup bedded) rebuilt & upgraded 4R100
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 164K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 241K (no engine repairs)
2007 BMW 550i 6MT 146K, Stuff breaking all the time that would last twice as long on a Kia or Hyundai, sad. Drives great though.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
