Can you Clean Injector Spool Valves? - Diesel Forum - TheDieselStop.com
Old 11-16-2006, 09:14 PM   #1 (permalink)
So Ford has released the new flash for 6.0L CALIBRATION TO REDUCE COLD ENGINE DRIVABILITY CONCERNS Technical service bulletin (TSB) 06-22-03.
I understand this flash cycles the injector spool valves for 30 seconds when you shut of the motor. This is susposed to help with the sticking of the injectors on start-up.
I have 2004 6.0L Build date 8/03, that I just bought. It has 112,000 so back to the dealer will be costly.
When I cold start it in the morning it misses and has no power until it warms up a bit. If it's plugged in it does fine fires right up. After reading this forum it seems I may have some sticky/ gummed up injector spool valves.
So far here is what I have done:
Added 2 quarts of engine flush to motor oil, let idle for 10 min then dumped and refilled with new filter and rotella 15-40.
Changed both fuel filters (the one at the fuel pump was black?)
Dumped a quart of Diesel Kleen to 20 gallions of fuel and drove interstate for 250 miles @ 70 mph.
I think the previous owner did not change oil or filters per schedule that's why I am thinking sticky spool valves. When it's warmed up it runs great.
Has anyone tried to clean the injectors? and or had positive results from the new flash?
99 F250XLT,CC,SRW,auto,V10,4.30LS 34K miles
04 F250XLT, EXT auto 6.0L, 122K
Tim Garst is offline
Old 11-16-2006, 09:39 PM   #2 (permalink)
Re: Can you Clean Injector Spool Valves?
I have not done the following but I've heard of guys draining all but a couple quarts of oil then adding Kerosene in the same amount as oil that drained out. Run engine on idle for about 5-10 minutes not gunning the engine. Drain that oil/kero mix, replace filters and refill with oil. The sticky injectors should fire better - at least for a while.
There are probably some old-timers that can comment on this procedure.
Clevelandjim is offline
Old 11-16-2006, 10:10 PM   #3 (permalink)
I don,t think you fully understand the purpose of that TSB. Its not that your injector spool valves are dirty or gummed up. They are essentially broken in. Just as the engine itself gets broken in over time and mileage. Because they are "broken in", it allows for a closer tolerance between the spool valve and bore causing increased striction. The cycling of the spool valves on shutdown is to shake the oil out of the valve to decrease striction. ( Grampy_Jim has tried to explain it at least a dozen times). [img]/ubbthreads/images/graemlins/smile.gif[/img]
My 04 seems to be suffering from the same symtoms, although it doesn,t sound like its as bad as yours. I will eventually probably have to take it in and have the TSB performed. [img]/ubbthreads/images/graemlins/smile.gif[/img]
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
Old 11-16-2006, 10:30 PM   #4 (permalink)
Banned
Anyone that fully understands how the HEUI injector works would back away from your idea very quickly. The opportunity for premature wear or failure in the high pressure oil system it to great.
There are no "homegrown" workarounds that will achieve the results of this new FICM strategy....
FWIW, the injectors affected by stiction are not "sticky". They are not coated with any deposits that resists their traverse from one end of the bore to the other.... they are, however, the victim of fluid dynamics and physics.
GrampyJim is offline
Old 11-17-2006, 09:04 AM   #5 (permalink)
DJ,so when the plungers and bores wear they get tighter, interesting.........
The ends will lap and get smoother but they won't tighten up in the bore.
2000 F-350 Lariat SC PSD SRW 4X4, Six speed, Dark toreador red, Ball Bearing Turbo, Coolmist Stage 2, Banks Big Hoss 5 chip, Big Head Actuator and 3.5 down pipe with Dynomax exhaust, PacBrake Exhaust brake, AIS Air Filter, Jordan brake control, 20K Reese fifthwheel Hitch, Reese folding gooseneck hitch, Rhino lining born 5/00
1998 35' Challenger fifthwheel double slide with 3600 Onan MicroQuite Generator,Washer/Dryer.
Wife drives a Black 2003 Excursion 4x4 Limited, 6.0 PSD
diesel_doctor is offline
Old 11-17-2006, 10:09 AM   #6 (permalink)
Grampy_jim, thanks for the info
This morning, cold it would only tach up to 2 grand and maybe 15mph.
Do you think the new flash will cure the problem, or I need the flash plus injector's.
Is anyone doing reman's or where is a good place to get them.
All
Tim
Old 11-17-2006, 10:36 AM   #7 (permalink)
I agree with you.
Thats what I was trying to get across, but I didn,t want to write a book on the subject. [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img]
DRJ48 is offline
Old 11-17-2006, 11:11 AM   #8 (permalink)
RatherBNtheWoods's Avatar
I would really question whether to put diesel, or most any flush, into the crankcase of the 6.0 PSD. The PSD has a reservoir of lube oil, that doesn't drain when you change the oil, used for the HPOP. So it would take a while for the diesel/flush to get into the HPOP(at full strenght) and through the injectors, and then when you drained the flush out, you wouldn't get it all out, because the reservoir would still be full of the diesel/flush. Think I'd pass on the idea.
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 55 gal aux fuel tank. A real pig from a stop, give me 15' and she'll slowly come to life, then watch out!
165K miles, 12 injectors, EGR cooler, Fuel pump, 8 glow plugs, GPCM, FICM rebuilt FoMoCo engine at 150K under 7/200 warranty.
RatherBNtheWoods is offline
Old 11-17-2006, 12:31 PM   #9 (permalink)
That would be a really good way to destroy your engine! [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2003 F250 XLT Sport Ext Cab ESOF FX4 6.0L TorqShift, Sonic Blue/Black Leather.
BrakeSmart Trailer Brake controller.
Leer Cab high Browning Edition Cap.
2004 SunnyBrook Solanta 28' TT small slide 7800#
35 Years in the trenches!
Retired Machinist & Manufacturing Engineer for fuel control systems for very large Diesel Engines. Locomotives to Super Tankers.
Designed and trouble shot manufacturing processes for stuff from Design Engineers. Sometimes had to wrestle for design changes.
Designed and built tools and equipment to machine, assemble, disassemble, repair and test.
Wisdom comes with age, but sometimes age comes alone.
"Nothing is FOOLPROOF because fools are too ingenious"-Mark Twain
johnmart is offline
Old 11-17-2006, 11:01 PM   #10 (permalink)
If you really want to try to clean the oil side, buy something made to do it.
Lubrication Specialists markets a product just for the PS engine. It's two quarts and you add it too your oil at a change.
I tried it and pulled a sample at the next change to see what it did, I haven't sent it off yet.
Old 11-18-2006, 05:42 PM   #11 (permalink)
Re: Can you Clean Injector Spool Valves? UPDATE
I took the truck to the dealer and it had never been back since new and was needing the 05E15 emissions recall. So I got the latest and greatest Flash with the 6.0L CALIBRATION TO REDUCE COLD ENGINE DRIVABILITY CONCERNS Technical service bulletin (TSB) 06-22-03, at no charge. It buzzes the injectors for 30 second upon shut down.
So if you have never been back for the recall you can get the new flash for free. Its going to be cold in the morning I will see how it goes with the new flash.
Tim [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 11-18-2006, 05:52 PM   #12 (permalink)
Mine has never been reflashed either. Do you think I should have it flashed?? I am getting 21MPG and it runs great. I don't want to mess up my good fuel mileage.
2003 6.0L xlt, ex cab, shortbed, 4X4.
SCT tuned from Innovative Diesel 413RWHP
jesshwarren is offline
Old 11-18-2006, 08:10 PM   #13 (permalink)
Tim, Please let us know if this helps your cold start issues. I am also interested, as I am also having minor cold start issues. Thanks for the update. [img]/ubbthreads/images/graemlins/smile.gif[/img]
DRJ48 is offline
Old 11-18-2006, 08:26 PM   #14 (permalink)
Personnally I would not mess with it, if its running good and you have no issues. You might not like what you get. It sounds like you have a good one with that kind of mileage. If its not broke, don,t try and fix it. [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img]
DRJ48 is offline
Old 11-18-2006, 10:50 PM   #15 (permalink)
where is this stuff available?
2003 Ford F250 Powerstroke (tow vehicle)
1975 Porsche 914 GT3 (racecar)
1969 Porsche 911 GT5 (racecar)
1965 Porsche 356SC (driver)
Iracea911 is offline
