Cant build over 20 psi! - Diesel Forum - TheDieselStop.com
Old 07-30-2009, 11:40 PM   #1 (permalink)
My Photos: (6)
Send a message via AIM to blizzardwarrior7
I've got a 2006 that just recently wont build past 17-18 psi of boost. Even if I stomp on it, it goes right to 17-18 sometimes 19 psi, and thats it...It seems to have less power from a stop also....Actually started last week, I havent had a tuner on it since June...And its got studs... Any idea what may be causing this?
2006 F250 cc/sb sct, studs egr delete, 100 shot injectors, fass fuel pump, twins, rough country 4-link 8" Lift, 38"x15.5" Dick Cepeks, 20x12 Rockstars, 4" Dual Exhaust, Ranch hand bumpers Front & Rear
2002 F350 XL RC/LB Pro Comp 6.5" Lift, 37"x13.5" SuperSwamper M16s, Stage II's, GTP38 turbo, DP Tuner, AFE intake, 5" exhaust, JW Slush Box, AIH Delete, CCV Mod, Zoodad mod, 5.6k mod, FPR Shim, ATS Flex Plate, ATS Torque Converter, AirDog FP-150, Fluidampr.
2006 Ram 2500 QC/SB Smarty, 5" straight pipe, edge, Leveling kit, 35x13.5" mickey ATZs
2006 International CXT DT466 300 hp 860 tq Diablo powerpuck, 6" straight pipe into 7" single stack
blizzardwarrior7 is offline
Old 07-31-2009, 01:09 PM   #2 (permalink)
My Photos: (6)
Also....Not smoking at all or anything....If I try and powerbrake, I can only build around 5 psi of boost, and it wont even spin the tires.
Old 07-31-2009, 05:01 PM   #3 (permalink)
wpfd's Avatar
My 2003 is basically doin the same thing. I pulled my EGR and cleaned it up. But i think the vanes are stuck on my turbo and i gotta get it pulled and cleaned up, or im buyin a new turbo for it now.... look into EGR then go towards havin ur turbo pulled and cleaned up if it can be...
The EGR is easy and cheap to clean up yourself. Turbo is more expensive and difficult...
2003 Ford F350 6.0 Crew Cab/SB/SRW 4x4
Edge Juice Platinum w/ Attitude Controller
Bully Dog RFI Intake
MBRP 5" Turbo Back Straight Pipe Exhaust, Cat Delete
180 Watt Whelen Monster Box Strobe kit. 8 strobes 22.5 watts each.
Rough Country R9000 Shocks
Dick Cepek FC-II Tires
Western Vee Plow
piloting a fire breathing, over boosted, turbo charged, tire smoking, panic inducing, ear drum abusing, spinal adjusting, snow storms nightmare. 2003 f-350 6.0, kinda fast...
wpfd is offline
Old 07-31-2009, 05:13 PM   #4 (permalink)
My Photos: (6)
Checked the EGR, its not that, I actually cleaned it this spring....How much $ is to pull the turbo and clean it? Is it covered under warranty?
Old 07-31-2009, 06:42 PM   #5 (permalink)
william_04_X's Avatar
Get yourself one of these kits and follow these instructions to do it yourself..
04 EB X w/03 PSD
william_04_X is offline
Old 08-10-2009, 05:12 AM   #6 (permalink)
i once had trouble building boost, i had split cac hose on the backside where i could not see it at first.
Ken
2003 f-350 CC LB dually 6.0l, edge platinum with A2, afe stage 2 intake, mbrp turbo back cat delete, intake elbow, rebuilt upgraded trans, egr cooler bypassed
hulabaloo is offline
Old 08-11-2009, 05:53 PM   #7 (permalink)
Turbo exhaust inlet
I had the same problem. Check for a leak in the flex bellows joints on the turbo exhaust inlet. Look at your exhaust manifold and follow the pipes you will see 3 flex joints two on the pasenger side and one on the driver side.
check them with the engine running be careful not to touch the pipes as they will be hot. Perform this with a cold engine. look around the flex joints and listen for leaks confim them using a piece of paper if it flutters there is your leak.
If one is leaking replace all three as the anneal (harden)when they get hot.
FK000@aol.com is offline
Old 08-11-2009, 07:28 PM   #8 (permalink)
Mine did the same thing. I really noticed it when I pulled the camper though. It would downshift and try to biuld power, but it lost speed and would shutter. If I let off of it, it would start to build speed until I really stomped on it and it would do the same thing. After another week it started to idle rough and then barely at all. Cause....number 8 injector. After that, it ran like new again.
derekoh is offline
