CarQuest Oil housing - Diesel Forum - TheDieselStop.com
Old 03-29-2009, 10:27 PM   #1 (permalink)
Hey guys, I screwed up and broke my stock oil filter housing, I was buying wix filters at the time from carquest and went ahead and got a carquest oil filter housing has anyone messed with these? The other day I bought a motorcraft filter because they were out of wix and it had no place for the o ring, I dont know if I should go out and buy a new housing from ford or not and cannot remember what the stock housing looked like. I am very confused at this point and any help would be appreciated.
The Know is offline
Old 03-30-2009, 12:17 AM   #2 (permalink)
Scot06's Avatar
When you say "housing" I assume your talking about the plastic cap that goes over the filter on top of the metal housing (under the hood). If so? pull your HFCM (fuel) filter under the truck. (behind driver's side frame rail under driver's door) They both use the same plastic cap. Take a look at the parts and see if they're the same.
If you don't have a 6.0 and posted here by mistake? Ignore my post!!!
www.cj-servicesinc.com/350.htm 06 F-350 4X4 XLT CREWCAB 6.0 w/ 160K
www.cj-servicesinc.com/FS2500.htm
FS-2500 bypass filter info.
Line-X in bed and color matched line-X where you would normally find the 2 tone paint on bottom. http://www.cj-servicesinc.com/linex.htm
2000 Silverado 1500 Wife's ride. 225K and runs like new
Scot06 is offline
