Cat delete - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 10-14-2013, 09:29 PM Thread Starter
Mt7
Cat delete
Hello everyone I'm new here and have a ? About 3 weeks ago I did a cat delete 2006 6.0 Since I did that it started blowing white smoke idle only. But not all the time. Egr valve not wet just dry with soot on it no coolant loss or power loss. Rev up a little smoke quits. Just wondering if the cat delete would cause anything like this?
Mt7 is offline
post #2 of 7 (permalink) Old 10-15-2013, 12:47 AM
Jack Lester's Avatar
Wouldn't think it would cause that... I have mine deleted also as well as the muffler...
Jack Lester is offline
post #3 of 7 (permalink) Old 10-15-2013, 03:42 AM
Has anyone got better mileage from a cat delete?
vacuumbed is offline
post #4 of 7 (permalink) Old 10-15-2013, 08:14 AM
HeavyAssault's Avatar
My Photos: (6)
What are the temperatures during start-up?? Where are you located?
More street cred yes. MPGs..not really.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
post #5 of 7 (permalink) Old 10-15-2013, 10:03 AM
did mine long long time ago hoping for better mileage,I'd have to think it would help some, but it is so little I can't tell......maybe .2 to .4 MPG better than before,but that could also be to different driving habits.....
2005 Super Duty Crew Cab, showroom stock....
2005 sd is offline
post #6 of 7 (permalink) Old 10-15-2013, 10:14 AM Thread Starter
Mt7
South Alamama. Temp rarley gets to the freezing point?
Also is there anyway to if the egr valve itself is bad?
Mt7 is offline
post #7 of 7 (permalink) Old 10-15-2013, 10:35 AM
danlane6.0's Avatar
I've got 4" straight exhaust (no cat/muffler) on mine and it does the exact same thing. But its very clear faint greyish white smoke. It smells only like strong rich diesel exhaust. I would imagine this is entirely normal since there is no restriction whatsoever ( especially cat being gone) on the exhaust, and being a diesel. If it smells like coolant then you have a problem, but from what I've heard from numerous sources, I believe its typical on a diesel to have atleast some smoke being straight piped. Of course, it also could be running rich, hence the reason guys with tuners click em on and blow thick black smoke due to injectors dumping way more fuel in the cylinder.
'05 F350 srw 6.0
Crew cab
Long bed
Lariat FX4
325x65x18 Nitto Terra Grappler a/t
Pro Comp 2.5" level lift
MBRP 4" turbo back straight no muffler/cat
Black billet aluminium ford grille and tailgate emblems
Sounds wicked, hauls a$$, turns heads, love it.
danlane6.0 is offline
