Cat Plug - Diesel Forum - TheDieselStop.com
Old 05-04-2005, 01:17 PM   #1 (permalink)
Cat Plug
Over time and miles, are the cats going to plug up causing high egt and poor performance? It seems a poorly designed EGR system may add to the problem. If so will Ford step up for replacement? Anyone with fairly high mileage run into this problem?
'04 F250 SC XLT 4X4 6.0 TS - Muffler Delete, Mobile 1
'73 F250 LWB XL 4X4 390-Far From Stock
'59 Plymouth Sport Fury 361 Golden Commando-Sweet
'85 Yamaha Vmax 160hp-Scarry
'80 Honda CBX 6cyl-Cool
hidesert is offline
Old 05-04-2005, 03:57 PM   #2 (permalink)
hitecdan's Avatar
My Photos: (22)
Re: Cat Plug
Well, I can answer one question with some confidence.
"If so will Ford step up for replacement?"
Only if it's under warranty, and them, maybe......... [img]/ubbthreads/images/graemlins/smirk.gif[/img]
My html Version of the 6.0L Bible Now with 2005 Updates
$5 AIC
Born on date: Jan 20, 2003
Number of times the EGR valve has been replaced/cleaned: 0 (updated: 4/15/2010)
The United States Constitution © 1791, All Right Reserved.
hitecdan is offline
Old 05-04-2005, 04:10 PM   #3 (permalink)
Re: Cat Plug
IIRC, here in CA, the mfg is responsible for the mandated emissions systems for 100k... If that is correct, then Ford will be required to step up.
04/04 F350 Lariat 6.0 TorqShift CrewCab Dually Longbed towing a 38'TPD goose. 2004,2005,2006 E2 Champion National Auto Sports Association's 25 Hours of Thunderhill race
civicrr is offline
Old 05-04-2005, 08:27 PM   #4 (permalink)
Re: Cat Plug
Looks like 5 years or 50k under the Emissions Defect clause of the warranty (over 8500 GVWR)
Mark
2004 White F350 XLT, CC, SB, 4x4, 6.0L Auto, 3.73LS, Camper Pkg, Skid Pkg, Edge 2" Mini Spring Pack, Bilsteins, MBRP Exhaust, FluidAmpr, Elite Regulated Return (55 psi), Airdog, Weld Evo Velociti & LT285/75-16
Built: 11/03/03
4x4Mark is offline
Old 05-04-2005, 10:38 PM   #5 (permalink)
Banned
Re: Cat Plug
We replaced a lot of cats this past winter.... Now that the warm weather is here, extended idling and wet stacking aren't such a concern. Cats will be covered under any emission controls warranty.
GrampyJim is offline
Old 05-05-2005, 02:24 PM   #6 (permalink)
Re: Cat Plug
This is good to know as it would seem that soot and cat converters probably don't work well together. Thanks for input.
hidesert is offline
