Old 11-02-2009, 11:41 AM   #1 (permalink)
Catastrophic Engine Failure
Hi
Our E450 Super Duty has a 6 Litre Powerstroke diesel with no aftermarket mods. On its first long trip to with 5800 miles total on the clock the engine has failed terminally. From what the engineers have seen without stripping it down it appears to have had a piston failure and oil pan fire. I have contacted Fords countless times and although they have admitted I have a valid warranty they are being evasive. I've since found out that Fords had major problems with this engine. Anyone else had problems that can advise me on how to proceed?
Steve
steveb19 is offline
Old 11-02-2009, 12:26 PM   #2 (permalink)
speedrcr78's Avatar
Have they told you that they are not going to fix it??? Are they blaming it on you? I think that when an engine blows up under warranty they really investigate it before replacing it. I have a 04 550 that I use as a wrecker it has 250k with relatively minor problems.
speedrcr78 is offline
Old 11-02-2009, 12:39 PM   #3 (permalink)
OT
My Photos: (6)
Steve..e series 6L isnt same exact eng. (hp/tq etc) as 6L in PSD. Maybe try other forum. But, if still under 3/36 oem warr. it should be covered 100% & fixed or under 5yr.PT warr. if it has one. Why is fmc being evasive, good Q. Maybe diff. in how repairs done, unless something else going on your not saying. I dont know? Good luck!
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23'
OT is offline
Old 11-02-2009, 01:06 PM   #4 (permalink)
aekrogh's Avatar
My friend at Ford has to take pictures of the destroyed components and send them to International for Approval prior to doing warranty engine repair. He says that sometimes between disassemble and approval may take several days. He said it sometimes takes International a day or two for approval or if it is something unusual then they send a rep out to look at the engine and the truck(looking for aftermarket items that they can use to void your warranty), after that then it is whether the dealer has a complete motor(if that is the warranty fix) in stock, or if they are going to put parts into yours to get it running. If you think it is taking the dealer too long to get back to you call the Service Manger and if that does not help call Ford Customer Care.
Late 99 SD PS CC SB 4x4 Lariat. 7.3l TS 6xchip Stock-140hp , Banks 6gun, Full Banks Gauges, 4"SS turbo back exhaust, UMP Intake w/ Donaldson Filter, Auburn posi F&R 3.73, ATS Trans W/ 5Star converter and CoPilot, 18k trans cooler, Dynatrac FreeSpin front hub kit, ITP oil X over, ITP boost regulator, Aero Fuel Tanks Replacement 55 Gallon tank, New timing cover,oil pan,oil cooler, water pump,turbo petastel, reman HPOP, new fuel filter housing, slotted brakes all 4 corners W/ Ceramic pads, Adjustable trac-bar, Front 1.5" level kit only. 188,000 miles 10/1/09 Best mpg 27.3..
Early 99 CC LB 2WD Manual 6....Stock 198k and running strong, only repairs Clutch, water pump, alternator.
2006 CC LB 4WD Lariat 6.0l 5R110 Stock 115k "Dad's"
aekrogh is offline
Old 11-02-2009, 02:17 PM   #5 (permalink)
rock_doctor's Avatar
I would swing by and take your own set of picture, just in case you need them. I would also pull a sample of the oil before they drain and dump it (just for your records). I would also make sure you have a set of all papers for your records. Good luck
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 11-02-2009, 03:33 PM   #6 (permalink)
Originally Posted by steveb19 View Post
Hi
Steve
You may not get many comments without several details like,year model,what does"evasive"mean,how long has it been at the dealer and anything else you care to add. It takes time and Ford may be trying to determine why it failed so they can't tell you any details yet. Even tho the 6.0(as well as anything mechanical)has problems,I'm having a problem wraping my thoughts around 5,800 miles. Is that milage indeed correct?
2004 F250 CC 6.0 PS , no mods
da-bees is offline
Old 11-02-2009, 04:00 PM   #7 (permalink)
fxdwgi's Avatar
Hi
Steve
This post smells fishy......
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Front Bull Bar w/ K.C. Daylighters * Draw Tite Fold Over Gooseneck * Gauges whited out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM *
Sitting in garage waiting to install: 6.0 IC
The REAL toy....
http://community.webshots.com/album/561972003NGydsT
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline
Old 11-03-2009, 06:06 AM   #8 (permalink)
Fishy?.
It is a 2006 E450 Ford Super Duty with ForestRiver motor home body.
It did 2000 or so miles in the USA before coming to the UK.
Ford USA have put it in writing that the warranty (100,000mile,5 years) is valid but have no Official agent in UK. After three months they have finally agreed that an independant they have done business with for many years in Mildenhall (250 miles away) can do it, but here is the catch. They want me to pay for the low loader down there ($1750+) pay the agents to remove and strip engine and send back to the USA, pay for the new engine and shipping and installation. (The cost of this in Europe is in excess of$30,000. And THEN in the fullness of time they might agree the engine! The engine let go in the South of France with 5800 miles total on the clock (before it had even reached the first service!)and it has already cost $7000 to recover to UK.A French garage had a quick look , the oil was burnt in the sump and they reckon at least one piston is holed .
Ford Uk say they are embarrased by the poor service and have talked to Ford USA a lot, but neverthe less the truck is still not roadworthy.
steveb19 is offline
Old 11-03-2009, 06:08 AM   #9 (permalink)
We offered to pay to have it stripped and pics emailed but thats not the end of it-I've just answered post below comprehensively. Thanks for the help
Steve
steveb19 is offline
Old 11-03-2009, 06:12 AM   #10 (permalink)
VIN number is -1FDXE45P56DA19153
steveb19 is offline
Old 11-03-2009, 06:16 AM   #11 (permalink)
Ok thanks for that . Yes the mileage is genuine and its had no modifications at all. It has been parked up for most of the time since it was purchased. This was the first long trip-I've just put comrehensive reply to another post .
Steve
steveb19 is offline
Old 11-03-2009, 04:07 PM   #12 (permalink)
OT
My Photos: (6)
S19..lousey $$$ situation to be in. Good luck on outcome!
OT is offline
Old 11-03-2009, 06:31 PM   #13 (permalink)
MikeL46's Avatar
Fishy?.
At that point, it is probably a bunch cheaper to ship the truck to the US and get the warranty work done there.
Mike
125W solar panel. Sportsmobile off-road trailer.
71,257 miles. 16.49 mpg average
From Cal to Alaska and Key West and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires. 46 Gal tank - harpooned pump vent tube.
Scangauge DieselSite Coolant Filter
165 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, Batteries not under warranty.
MikeL46 is offline
Old 11-03-2009, 06:43 PM   #14 (permalink)
I wonder if that fact it was not regularly driven lead to the failure. I bet you will find a bad injector over fueled overheating the piston which then melted... As the liquid aluminum dropped into the oil pan started burning the oil. There are not many cases of this but a few where injectors went bad which did in turn melted a piston.
I meant to take pictures of the engine as it is pulled apart. I suspect in the end they will take care of it but since you are not in the US they likely will drag their feet on it. Major repairs generally take an Ok from Ford and International. Since they both are sharing warranty costs for the 6.0 it does slow down the paperwork.
Old 11-04-2009, 07:25 AM   #15 (permalink)
Mike
Offered to ship it back from Liverpool(10 miles away) got reasonable price for shipping both ways. Ford wont commit themselves to the warranty (that they have already put in writing) that we have. With their present attitude would you pay and send your truck 3000 miles where its out of your control with no firm agreement?
Steve
steveb19 is offline
