Changed fuel filters today - Diesel Forum - TheDieselStop.com
Old 04-28-2005, 01:20 AM   #1 (permalink)
snoboy's Avatar
Swapped out both fuel filters today. 36mm for the frame filter and 24mm for the engine mounted filter. Used Wix kit # 33559 $37.25 purchased from http://www.filter1.com/ . Drained the HCFM (6mm allen) removed and replaced filter, replaced O-ring reinstalled cap torqued to 25 fig newtons and done deal. Used 24mm socket for engine filter, removed and replaced filter, replaced O-ring and reinstalled cap, torqued to whatever fig newtons the cap said and boom! done deal.
I had paid the dealer to do this at 15,000 miles and I think it was a fair bit over $100. So this time I thought I would do it at 30,000 miles. Glad I did it only took about 20min. total time and saved some money [img]/ubbthreads/images/graemlins/biggrin.gif[/img]. Plus it gave me a reason to check every thing out under the truck and all looks well [img]/ubbthreads/images/graemlins/smokin.gif[/img]. Just thought I'd share. Mike
-12/02 built 6.0
-FX4 Lariat supercab 4x4.
*Truck modifications*
-Banks turbo back exhaust
-DJs Fuel+ Intensifier fuel system
-SCT X3 DJs "tow w/ Jake brake"
-Dieselsite coolant filter
-4.30 gears
-CCV reroute
-Fumoto drain
-Autometer Cobalts in woodgrain pillars.
-Goodyear 19.5 G-124 14-ply on Vision wheels
-Concept Patterns "burnished" F/R diff. covers.
-Ride-rite airbags
-Rancho RS 9000XLs w/incab remote
-Torklift Superhitch
-Current oil: Cenex Maxtron 15w40 synthetic blend
snoboy is offline
Old 04-28-2005, 08:03 AM   #2 (permalink)
CaptSkup's Avatar
Re: Changed fuel filters today
Routine maintenance on the 6.0 is very easy, the easiest of any car/truck I have ever owned. And once you find Filter1 for your filters, the cost is very reasonable. I now change the inline transmission filter every other oil change because it is so easy and the filter is inexpensive at Filter1. Draining the fuel with the 6mm wrench is the secret to making filter replacement much easier and less soaking. I sure love my truck. [img]/ubbthreads/images/graemlins/grin.gif[/img]
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
Sea Ray 240 Sundeck
http://community.webshots.com/user/C...host=community
CaptSkup is offline
Old 04-28-2005, 10:23 AM   #3 (permalink)
My Photos: (5)
Glad I did it only took about 20min. total time and saved some money [img]/ubbthreads/images/graemlins/biggrin.gif[/img]. Plus it gave me a reason to check every thing out under the truck and all looks well [img]/ubbthreads/images/graemlins/smokin.gif[/img]. Mike
And most importantly, you know it got done right. I enjoy doing the regular maintance on my PSD, glad you had a good experience also.
2004 F-250 CC FX4 Lariat PSD 6-Speed with moonroof, camper package and AIC. Medium Wedgewood Blue over Arizona Beige. Retrax Bed Cover. Cabelas Trail Gear Floor Mats. Wet Okole Seat Covers. Airaid Intake, MBRP exhaust. Edge Juice Platinum with Attitude.
Truck pics
deacjrt is offline
Old 04-28-2005, 10:27 AM   #4 (permalink)
FamilyRide's Avatar
Ya, it's not that bad, it's not that expensive, but no one will get near you for 2 days while the diesel smell fades. [img]/ubbthreads/images/graemlins/laugh.gif[/img] Greta way to get some "me" time! LOL [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 05-17-2005, 10:17 PM   #5 (permalink)
help,
I have no problems changing the 2 fuel and air filters on my 03 6.0, but where is the in-line trans filter? Is there any other filters that i need to change?
tmblaster is offline
Old 05-17-2005, 10:42 PM   #6 (permalink)
snoboy's Avatar
The tranny filter is forward, slightly right of center and just behind the radiator down low. Its in a cast housing and it looks like this http://community.webshots.com/photo/...68087900AkpjEx The bright over exposed thing with wrench flats on it.
Two fuel filters, oil filter, an air filter, and the external tranny and you've covered your bases [img]/ubbthreads/images/graemlins/smokin.gif[/img]. Hope this helped [img]/ubbthreads/images/graemlins/phoney.gif[/img]
-12/02 built 6.0
-4.30 gears
-CCV reroute
-Fumoto drain
-Ride-rite airbags
snoboy is offline
