Changed XMSN external filter today - Diesel Forum - TheDieselStop.com
Old 05-05-2005, 08:59 PM   #1 (permalink)
snoboy's Avatar
OK as you know I did the fuel filters a few days ago and all went well. So today I thought I'd do the XMSN filter. I had the tranny flushed at the dealer at 15,000 miles just because [img]/ubbthreads/images/graemlins/shrug.gif[/img]. Well I thought I'll do the filter to take me through the interum (I'm at 30,000mi now) until I flush again at 45,000mi. I used a #58904 WIX from Filter1 for $9.08. I used a 7/8 socket (dont know metric size but 7/8 works perfect), changed O-ring, wiped off the magnet/base (which was very clean) and inside the housing, popped in the new filter and tightened. I also pumped the 4 steering zirks with grease. Filter service on this truck is fun and gives me a nice warm fuzzy feeling. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Has any of you guys done a pan only drain and refill just to freshen up the fluid?
-12/02 built 6.0
-FX4 Lariat supercab 4x4.
*Truck modifications*
-Banks turbo back exhaust
-DJs Fuel+ Intensifier fuel system
-SCT X3 DJs "tow w/ Jake brake"
-Dieselsite coolant filter
-4.30 gears
-CCV reroute
-Fumoto drain
-Autometer Cobalts in woodgrain pillars.
-Goodyear 19.5 G-124 14-ply on Vision wheels
-Concept Patterns "burnished" F/R diff. covers.
-Ride-rite airbags
-Rancho RS 9000XLs w/incab remote
-Torklift Superhitch
-Current oil: Cenex Maxtron 15w40 synthetic blend
snoboy is offline
Old 05-05-2005, 09:04 PM   #2 (permalink)
Re: Changed XMSN external filter today
I did my FMF and my BASO filters a while back.
(that's Frame mounted fuel and Big A$$ Spin On)
What's an XMSN filter?
2008 F550 6.4 w/ pickup bed
kehale is offline
Old 05-05-2005, 09:15 PM   #3 (permalink)
XMSN=transmission [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2004 Black SC F250 XLT FX4 4x4 6.0 Torqshift
Flywheeler is offline
Old 05-05-2005, 09:27 PM   #4 (permalink)
oh
kehale is offline
Old 05-06-2005, 09:51 AM   #5 (permalink)
CaptSkup's Avatar
I do a drain and filter change according to Ford's maintenance schedule. What I do is drain the pan, remove it, clean the magnet, check the pan for anything that is not supppose to be there, reinstall the pan, change the inline filter and refill. Drive the truck for at least 20 miles, drain the pan again and refill. I know I am not getting all the old fluid out by not flushing. I am not worried about that. Transmission fluid does not get contaminated by byproducts of combustion or fuel saturation. Every other oil change I also change the in-line transmission filter. Thanks to the low cost of the filter from Filter1, I consider it cheap insurance. I also get the MerconSP from my dealer for a pretty fair price considering it is a synthetic fluid.
Also for those considering it. First transmission service I bought the filter that is inside the transmission pan, thought what the hell, since I am going to drop the pan anyways. This filter is nothing more than a screened pickup tube. In other words go by what Ford tells you, save the $20 I paid for the screen and leave it in. If you do decide to remove and replace it, ensure that the pink colored o-ring type seal comes down with the filter and does not get stuck up inside the port like mine did. Had to remove it with a scribe,
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
Sea Ray 240 Sundeck
http://community.webshots.com/user/C...host=community
CaptSkup is offline
Old 05-06-2005, 10:44 AM   #6 (permalink)
XMSN=transmission
Snoboy must be an ET. XMFR = transformer, when your reading schemeatics.
OMCUSNR is offline
Old 05-06-2005, 11:22 AM   #7 (permalink)
XMSN=transmission
He is actually a Boeing Test Tech for the 737.
or
he is a ARCD = a real cool dude
SlaughterHouse is offline
Old 05-06-2005, 01:15 PM   #8 (permalink)
Teebird's Avatar
How many quarts to refill when you just drain the pan? I may do that in addition to the filter.
2003 F250 XLT 4x4 Sport Crew Cab,
Built May '03, Bright Red, 6.0 Auto, ESOF 4x4, 3.73LS, 4.5" Edge Lift, 315/75-16 BFG KO A/T's, Polished/Clear Powder Coated Diff Covers, Weld Cheyenne 8 Wheels, Line X, Overhead DVD, Torza Tonneau Cover, 30' Fleetwood Gearbox Travel Trailer
Teebird is offline
Old 05-06-2005, 01:43 PM   #9 (permalink)
CaptSkup's Avatar
7&1/2 to 8 quarts. I bought twenty quarts at the dealer. Drain, refill,drive,drain,refill. Couple of spare quarts in the bed tool box.
Sea Ray 240 Sundeck
CaptSkup is offline
Old 05-06-2005, 03:35 PM   #10 (permalink)
Ok - I feel dumb.
There's an external tranny filter? Screw on (oil filter like)?
Where's this thing located?
Can you really change the tranny fluid like the oil now? I noticed the other day while under the truck for the oil it stated that the tranny pan gasket is reusable.
Is this in the manual?
TIA!
04 F-250 6.0 FX4 XLT CrewCab. ESOF. White over Silver. Alum wheels. 3.73. PC78Elite CB w/Wilson 1000. Fumoto quick drain oil valve. Access Cover bed cover. Carry's around two of the greatest little boys in the world!
Engine Born on 12/22/03
Truck Born on 01/04
Truck Purchased 11/4/04
TimsDiesel is offline
