Changing fuel filters, HFCM never quit draining - Diesel Forum - TheDieselStop.com
Old 05-16-2010, 03:13 PM   #1 (permalink)
I changed my fuel filters this morning and when I did the frame mounted filter it wouldn't shut the fuel off. Usually you drain the housing and it stops, this time I had a steady stream the entire time. Made a hell of a mess. I drained it into the same pan as my waste oil so its hard to tell, but I'd guess I drained close to a gallon of fuel before I was done.
Anyone had this happen before? Is this a sign of future problems? Anything I can fix?
06 F350XL rc,lb,manual 4x4, 6.0 PSD, 6 speed
Upfitter Switches
BCP Idle Control
55 watt halogen back up lights (4)
200 psi 5 gallon air system
Diesel Site Coolant Filter
HELLA FF50 Fog Lights
Custom Headache Rack
Custom Shovel Rack
Weatherguard Saddle Box
Weathergaurd Wheel Well Box
Herculiner wheel wells and rocker panels
Edge Insight with EGT and Fuel Pressure
MattShade is offline
Old 05-16-2010, 05:55 PM   #2 (permalink)
One of my two 06's did that once and I chalked it up to full fuel tank and a warm day. The HFCM is lower than tank and there is really no good reason I can think that wouldn't siphon out of HFCM every time you do a filter change but it doesn't. Regardless, I have had no issues and fuel pressure on that truck is good under load on the occasions I have checked it.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.30 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 foot double tandem axle flatbed trailer.
36 foot Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
jimmy is offline
Old 05-16-2010, 06:38 PM   #3 (permalink)
OT
OT's Avatar
M..know what your mean & yes it's kinda wierd. Over yrs. I recall couple time's while draining didnt think it would stop so I put plug back in. Usually 2 or 3 cups drains, then stops. I would imagine any water would flush out rather fast, certainly before loosing a gal. fuel. JMO!
Way I park front end is slightly down. I use 5 gal. bucket to catch fuel & upgraded plug works good. You can experiment, cap off & less fuel in tank. I'll find out soon when draining if it's gonna be normal/wierd?
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 05-16-2010, 06:41 PM   #4 (permalink)
69cj's Avatar
Three things you can do to prevent this. Change filters when tank is at 1/4 level or less, park on an incline with the front of truck on the high side and remove the fuel filler cap in case you have press. built up in the tank.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 05-17-2010, 07:13 PM   #5 (permalink)
Well at least I'm not the only one. I did have about 3/4 of a tank, and I can't remember if I've ever changed it with the tank that full before or not but it seems like that could be the cause. I'll keep that in mind for the next time around.
Upfitter Switches
BCP Idle Control
Custom Shovel Rack
Old 05-18-2010, 07:13 PM   #6 (permalink)
OT
OT's Avatar
After I changed oil I drained the hfcm. Front end slightly down, gas cap ON (not off) & fuel just under 1/2 tank. About 2 cups drained out (no water) & stopped. Cycled key on/off 3 times & fired up. Just another reason they call 6L's, snowflakes.
OT is offline
Old 05-18-2010, 08:31 PM   #7 (permalink)
topgun35's Avatar
same thing happened to me the other day water in fuel light came on and i filled the tank before i drained the water and thought it wasn't going to stop so i put the plug back in.
topgun35 is offline
