Re: Changing thermostat question
Haven't changed a thermostat on a 6.0, but if it is like the 7.3 it is fairly simple. Drain out a couple of gallons of coolant from the radiator drain(filter and reuse or dispose of properly, a coffee filter works fine). Then remove the upper radiator hose from the thermostat housing. Remove the thermostat housing and clean. Remove old thermostat and install new one. The 7.3 has a o-ring style gasket, if the 6.0 is the same replace the gasket and put a thin bead of grey silicone sealer on the mating surface around the gasket. Replace the housing, hose and refill with coolant.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB w/cat, Accufab, Edge Platinum/w Evo Trans Tune, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
