Anyone got a quick way to test your fuel pressure, and what pressure is expected to be from a good pump. I suspect I may be have some fuel pressure issues, but I'm not sure.
2006 F350 SD Crew 6.0 stock, except I did add floormats.
40-45 minimum. A good pump should be 50psi. If your dipping below 40 you have issues. What is your truck doing to? Have you changed the fuel filters?
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
At around 2100 rpm +- it seems to feel starved for fuel, kinda missing for a couple of seconds, or like a sputter, but there doesn't seem to be any real noticeable power loss. I had the drive train checked out about 2 weeks ago and there were 3 injectors changed (one bad the other 2 were weak) and it seemed like a marked improvement. The thing is the sputter wasn't an issue before the service. I don't know if they re flashed the control systems or not, I guess that would be a good place to start. I don't know if they checked the fuel pressure or not, but I would expect they would have. I plan to call them and ask if they checked the fuel pressure, and what were the results. What do you guys think?
FEBRUARY 2004 F350 CREW DUALLY,60K, 6.0L/6 SPEED/3.73/2WD,
EGR SPOOL, INSULATED WRAP CAC,BUTTERFLY DELETE,ACCUFAB INLET ELBOW,MUFF TUBE,BED COVER,BREATHER VENT MOD,OB1308 BY-PASS FILTER BASE,upgrade fuel return pressure spring 30# increase, velvet ride shackles, tranny cooler/filter,COOLANT FILTER,redline wetterbetter,1704A SUPERCHIP, SCHAFFERS 9000, 22MPG EMPTY @ 55MPH in cruise. Last fill up calculated @ 18mpg Hobbies- sticking my head out the window like a dog and hauling ass on the scooter rain or shine
Just a comment.... if you suspect a fuel pressure concern, it is vital to check the fuel pressure when the problem is happening. Checking fuel pressure at idle in the driveway is futile at best and can be misleading at worst....
nothing lower then 45 run around with 40 psi and youll be beating injectors out of it. sounds like it could be a high pressure oil problem, its usuall the higher rpms when your gonna feel a low fuel pressure problem.
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
