check air filter warning light - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 05-01-2007, 12:21 AM Thread Starter
Cant seem to get my light to go out after I went through some water.Pressed reset on the undicator under the hood wasnt really tripped.I had gone through some water mabye had some steam go into filter not sure.Is there somthing I am missing everything looks ok.
06 F-350 CrewCab 8" Rizer lift 37" ProComp Exterrains
fullthrottle800 is offline
post #2 of 9 (permalink) Old 05-01-2007, 05:25 AM
snoboy's Avatar
Re: check air filter warning light
My first guess would be that water got inside the connector and is closing the circuit ie. making continuity. Disconnect and see if light goes out. If so blow out connector and reconnect, light should stay out. Give it a try [img]/ubbthreads/images/graemlins/shrug.gif[/img]hope this helps
-12/02 built 6.0
-FX4 Lariat supercab 4x4.
*Truck modifications*
-Banks turbo back exhaust
-DJs Fuel+ Intensifier fuel system
-SCT X3 DJs "tow w/ Jake brake"
-Dieselsite frame mounted coolant filter
-4.30 gears
-BD Diesel CCV kit
-Fumoto drain
-Autometer Cobalts in woodgrain pillars.
-Toyo All Terrain AT II 285/75/18 4080lbs
-Concept Patterns "burnished" F/R diff. covers.
-Ride-rite airbags
-KYB Monomax shocks
-Torklift Superhitch
-Current oil: Rotella T6 5w40
snoboy is offline
post #3 of 9 (permalink) Old 05-01-2007, 08:35 AM
Black05's Avatar
You might also check the filter. If it became soaked with water, then it may be swollen/plugged enough to be causing the issue. If in doubt, change the filter. If the problem doesn't go away after changing the filter, save the old filter for later use. Don't forget to reset the filter minder.
Black/05/F350/XLT/CC/LWB/FX4/SRW/3.73/6.0L PSD/ TorqShift/Updated TBC/Upfitter Switches/SEIC Mod/Diesel Site Coolant Filter/Fumoto Valve/ITEC HFCM Drain Plug/Bilstein Shocks/BFG A/T 28565R18/Built September of 2004
Texas Proud.
God Bless our Armed Forces.
Black05 is offline
post #4 of 9 (permalink) Old 05-01-2007, 09:56 AM Thread Starter
Unplug the filter minder connector wire?
post #5 of 9 (permalink) Old 05-01-2007, 11:07 AM
Black05's Avatar
No, there is a yellow reset button on the end of the filter minder. Just push it and it should reset the filter minder.
Texas Proud.
Black05 is offline
post #6 of 9 (permalink) Old 05-01-2007, 12:03 PM
FamilyRide's Avatar
He did reset it.
I agree with snoboy, check the connection. Also like Black05 said, check the filter. The minder may just be working right. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #7 of 9 (permalink) Old 05-01-2007, 12:07 PM
Black05's Avatar
FamilyRide -- Thanks for the catch. I missed that he had already reset it.
Texas Proud.
Black05 is offline
post #8 of 9 (permalink) Old 05-01-2007, 12:13 PM
FamilyRide's Avatar
No problem. I meant to put a little smiley after that. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
I'm almost ready to take bets that the filter is actually restricted and the filter minder is just working correctly. It's rare to actually have one get restricted enough to set it.
post #9 of 9 (permalink) Old 05-01-2007, 12:16 PM
Black05's Avatar
True. The only ones that I've heard of occluded enough to trip the minder are where snow has gotten in the intake before the filter. I also am still betting the filter is water swollen and plugged.
Texas Proud.
Black05 is offline
