check engine light - Diesel Forum - TheDieselStop.com
Old 03-14-2010, 03:04 PM   #1 (permalink)
check engine light
05 f 250 6.0 diesel. Drove my truck this morning to the gym and when i came out and fired it up, the check engine light stayed on. I recently changed the oil and fuel filters. I used motorcraft oil filter and Rotella 5W-40 Synthetic and the fuel filters were both Racor but the truck was running fine before and after that so I am at a loss. I drove it home and it seemed to be running fine. The last thing I want is to have to go to the ripoff dealer! Does anyone have any thoughts/suggestions? Thanks
baxter6101 is offline
Old 03-14-2010, 03:12 PM   #2 (permalink)
wldwilliam's Avatar
Originally Posted by baxter6101 View Post
05 f 250 6.0 diesel. Drove my truck this morning to the gym and when i came out and fired it up, the check engine light stayed on...I drove it home and it seemed to be running fine
My CEL came on and I didn't notice any ill effects either. When I got around to taking it in (dealer), the turbo was the cause and it was replaced (rust and corrosion). You will need to have someone pull the code(s) if you can't do it yourself. If you post the code(s) here, one or more of the helpful guys on this forum will point you in the right direction.
2005 F350 | Lariat | CrewCab | 4x4 | 6.0 | 5 spd auto
Edge Insight & ScanGauge II monitors | Autometer FP gauge | DieselSite Coolant Filter | DR 2.5" level
18x10 Weld Evo Cheyenne 8 | 325/60r18 ProComp XAT | Upfitter Switches added | Extang Trifecta Tonno
Amp Research PwrStp | high idle mod | Ford F/P reg mod | latest EGR valve
03/06, 9K miles
oil leaks (r&r rear main seal and cam sensor), recall 05E16 (ECM recalibration), recall 05B32 (de-gas bottle fill level label applied & coolant level adjusted)
06/07, 22.5K miles
no 4x4 (r&r left side vacuum hose), e-brake malfunction (r&r parking brake ratchet assembly)
01/10, 30K miles
oil leaks (r&r bed plate, rear main, rear cover gaskets & o rings), CEL (r&r reman turbo, drain tube, update processors)
03/10, 30.5K miles
EOT +15°>ECT (r&r oil cooler, egr cooler, degas bottle & cap)
[all under warranty]
wldwilliam is online now
Old 03-14-2010, 03:19 PM   #3 (permalink)
Well first I'm going to advance auto to have them check the system with their computer, but I dont know how accurate they are...
Old 03-14-2010, 05:50 PM   #4 (permalink)
Codes
Advance auto's computer said it is PO 672 Glow Plug/Heater Cylinder 2. I then went to auto zone and there;s said the exact same thing. My truck is still under warranty, does anyone know if glow plugs are covered? I would think so-they are part of the motor...
Old 03-14-2010, 07:40 PM   #5 (permalink)
alexb's Avatar
Glow plugs are covered under the diesel engine and emissions warranties. Chances are the module has gone south.
Proud to be a member of Ford Doctors Diesel Technician Society
alexb is offline
