Clear DTC in HEC display? - Diesel Forum - TheDieselStop.com
Old 09-19-2005, 10:30 PM   #1 (permalink)
I set a 9318 (low battery voltage) DTC in my HEC this weekend. I have disconnected the battery to try and eliminate the code, but it remains when I reconnect. How long do you have to leave the batteries disconnected?
<font color="purple">2005 F350 Crew Cab King Ranch, Dually, PSD, Torqueflite, Tow Haul, FX4, ESOF, 4.10LS, Skid Plates, 15K hitch, Upfitter switches and Brake Controller, Automatic Temp Control and all the power and heated stuff...</font>
Mofishin is offline
Old 09-19-2005, 11:23 PM   #2 (permalink)
Banned
Re: Clear DTC in HEC display?
Ummmm.... if you disconnect the battery, the battery voltage "goes low". This will set your odometer code. I can only suggest reconnecting the battery and forgetting about odo codes altogether....
You will likely have an ABS code set due to the low volt condition.... the light will reset on it's own (though you will not know if another condition occurs while the light is on) or it can be reset with a capable scan tool.
GrampyJim is offline
