Clunking noise when hard right turn - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 05-22-2007, 09:24 AM Thread Starter
2005 PSD have noticed when turning to the right on a hard turn that I am getting a clunking noise in the right front. Also while sitting still and turning wheel all the way to the right will also get the same clunking. Ball joints??????
giveitsome is offline
post #2 of 10 (permalink) Old 05-22-2007, 09:46 AM
lari2001's Avatar
Re: Clunking noise when hard right turn
Probably some binding going on in your linkage, have someone listen while you turn the wheel to pinpoint what joint is making the sound. You could jack up the front end a few inches and stick a pry bar under each front wheel to see if there is any play in the balljoints or bearings.
2017 lariat F350 4X4 6.7, CC LB SRW pulling a 43' Road Warrior toy Hauler
2008 F350 lariat crew cab 4x4 srw lb 6.4 tuned - sold
2001 F350 lariat crew cab 4x4 srw sb 7.3 - Sold
2004 F350 lariat crew cab 4x4 drw lb 6.0 - Sold
1997 F350 xlt crew cab 4x4 off rd srw lb 7.3 sold
1978 custom Bronco lifted, 71 Lincoln 460 bored .030 on 35's
lari2001 is offline
post #3 of 10 (permalink) Old 05-22-2007, 03:22 PM
How many miles are on the truck?
That sounds like the description of ball joints that are pretty much dead.
2004 F350, 6.0, crew cab, long box, ISSPRO BOOST-EGT-PYRO gauges, 4" MBRP exhaust, Innovative Diesel SCT programmed, GOS Racing headlight harness upgrade w/Bright Box FLC, husky floor mats, LEER canopy, FabTech 3.5" hangers on 35" tires.
2001 GMC Yukon, all stock besides the 18" chrome wheels and the kids car seats.
1992 Toyota Terdcel.
2006 Desert Fox toy hauler.
2005 Yamaha YFZ450 - a toy for the sand.
1996 Yamaha Banshee - oh yeah, it's a ride in the sand!
Richman is offline
post #4 of 10 (permalink) Old 05-22-2007, 05:27 PM
I had a similar thing happen to me. Mine was a 4x4 hub that was stuck on one side.
Johny
2005 F-250 Lariat
Turbo-Back Magnaflow Exhaust cat-less
Edge Juice w/ Attitude
ARP head studs w/ new head gaskets July 2009 98K miles
10/24/2007 Stolen from work parking lot.
10/24/2007 Recovered after 6 hours, just North of Mexco. Damage: broken passenger door lock, broken ignition lock.
1995 32ft Fleetwood Wilderness 5th
1975 35ft 3 horse living quarters goose
JohnyLingo is offline
post #5 of 10 (permalink) Old 05-23-2007, 09:46 AM Thread Starter
31,000 on truck
post #6 of 10 (permalink) Old 05-23-2007, 10:34 AM
31,000 sounds a little early for the ball joints. I had mine done at 40,000 miles when they were wore out, it's amazing at the cost of these trucks and they wear out parts so quickly, to bad they don't install greasable ball joints directly from ford.
Richman is offline
post #7 of 10 (permalink) Old 05-23-2007, 01:56 PM
sootballz's Avatar
Mine was doing that and it ended up being my upper track bar bolt. Is your truck lifted at all? I thought it was my ball joints and changed them but it still popped when I turned. Now its all good.
2004 for CC SB white leveling kit plus alittle. 35 toyo'MT's on 18's, Fox 2.0 res. shocks,Air Bags, Edge Juice Attitude Platinum "hot", Dual diamond eye exhaust, Afe stage 2 Intake, ATS tripple loc TC,ATS input shaft, Red Eagle clutch upgrade, transgo shift kit, Shift pressure with HP on the Platinum, Bypass oil filter, FASS fuel system, 90 Hp DDP injectors. ARP head studs. Stage threee fuel system upgrade. 03 turbo...gota love the whistle.
1989 Ford F800 5YD dump truck, 6.6L inline 6 brazilian Diesel, ddp injectors, 5 inch exhaust.
sootballz is offline
post #8 of 10 (permalink) Old 05-23-2007, 02:08 PM Thread Starter
No all stock nothing changed on it since the day I rolled it out. Well it goes into the shop this coming week (once again) but like I always say, I have a darn good dealership and it makes the problem just a bit more easier to cope with.
post #9 of 10 (permalink) Old 05-23-2007, 02:51 PM
sootballz's Avatar
jack the truck up so the tire is off the ground, then grab under the tire and lift. I f the ball joints are bad it will be loose and clunk for you. If you replace them make sure you get the premium greasable ball joints.
post #10 of 10 (permalink) Old 05-23-2007, 03:45 PM
Is the truck lifted? If so make sure the Track Bar bracket is torqued to 400 ft/lbs, my truck had this happen and it was this this bracket.
JRMCCANN is offline
