code P0299 low turbo boost check engine light HELP - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 12-30-2010, 10:58 PM Thread Starter
I have a 2005 Ford Excursion 6.0 4x4 that's been to the shop twice in the last 2 weeks with the check engine light on. The code is P0299. The turbo was removed and cleaned in July for the same problem. I just recently installed a 4" turbo back exhaust no cat, not muffler. This is when the problem reoccured. They have put a new EGR valve in it and found that the exhaust backpressure sensor wiring was rubbed through so that was repaired. I just got it back today and the light is on for the 3rd time. I'm wondering if anyone has any suggestions or experience with this. I asked the tech if the exhaust could cause this problem and he said he's pretty certain it wouldn't. I know I'm not the only one driving a 6.0 with no cat or muffler so please help if you can!
skevac is offline
post #2 of 4 (permalink) Old 12-31-2010, 12:32 PM
MikeL46's Avatar
My Photos: (14)
I had to have my turbo replaced to get rid of that code. Sometimes cleaning just won't take care of it.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
115615 miles. 16.65 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
MikeL46 is offline
post #3 of 4 (permalink) Old 01-01-2011, 02:34 PM
jamartz's Avatar
I have stock exhaust with muffler delete. i had the code once about a month after I bought the truck, cleared the code and it hasn't reappeared since. From what I have read it is a pretty common code...just means that at some point the boost was not within the set parameters the computer is looking for. It could happen for just a fraction of time to throw code.
Can Be caused by a bad or sticking turbo but not always. Kind of a phantom code for these trucks.
Not 100% sure but I beleive this code is thrown for both underboost and overboost conditions?......correct me if I am wrong. I don't think there is an actual code for overboost, it uses the same code number if that occurs.
I got the code while towing my work trailer with the cruise set, going up a hill, it was lightly raining and the truck downshifted, spun tires when it down shifted and reved real quick- i saw the factory boost gauge actually spike into the red zone for a moment! Then CEL came on- I thought I toasted something but it ran just fine so I cleared the code and it hasn't come back since.
06 F350 CC LB Lariet FX4 6.0L PSD Auto
150K miles and counting
SCT X3 Tuned by Vivian- (Street, Tow, Looney
Quad Pod w/ EGT, EOT, ECT, Fuel PSI Glowshift Elite 7 series Gauges
MBRP 4" TurboBack off-road
Leveling Kit
20" Moto Metal 957's
295/65/20 Nitto Trail Grapplers
Vortex Spray in Liner
02 F-250 Crew Cab 4x4 auto 7.3L PSD. w/Bullydog 6 position flip chip.
00 Excursion V10 4x4 Limited - SOLD
96 F-250 PSD SOLD
94 Mustang GT H/C/I and NX kit SOLD
95 GT VERT all stock (wifes car)
jamartz is offline
post #4 of 4 (permalink) Old 01-01-2011, 08:55 PM
hawkeyediesel's Avatar
I had this code a little over a year ago, just a few days after buying my truck. The local dealer replaced the unison ring in the turbo and no issues since. They told me when I brought the truck in that there are two common issues for this code: 1) dirty turbo or 2) replace unison ring.
2006 F-250 Lariat Crew Cab | 6.0L Powerstroke | 4x4 Auto Tranny w/ 3.73 | ~105,000 miles | AstroStart Remote Start | LineX Spray-On Bedliner
Turnover Ball Gooseneck Hitch | Scangauge II w/ homemade mirror mount | Glow Shift Fuel Pressure Gauge | Glowshift EGT Gauge
Dieselsite Coolant Filter | CAT Delete Pipe | SCT Livewire tuned by Innovative Diesel
| River City Diesel EGR Delete | Blue Spring Upgrade
High Idle Mod | ARP Studs
2009 30ft Puma Travel Trailer | Approx 8000lbs when loaded up for the weekend!!
hawkeyediesel is offline
