Code P2099 or P0299??? - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 02-12-2007, 06:08 PM Thread Starter
Check engine light went on while cruising down the expressway @ 75 MPH. The truck runs fine, no noticeable differences. I brought it in to the dealership, they scanned it and got the code "P2099". He told me the code said "under boost on turbo", and that they have never seen this one before. He gave me temp readings of -4 and one of 188?? I have no idea what these were read from. They cleared the code, started the truck back up and within 2 mins of it running the light came back on. It has been really cold here lately (-10), and the truck has been plugged in.
What should I do next??
06' F-250, 6.0L PSD, AUTO, CC, SRW, SWB, 4WD, ESOF
4" turbo back MBRB exhaust
x-monitor
Air horns
cvucich is offline
post #2 of 13 (permalink) Old 02-12-2007, 06:14 PM
Re: Code P2099???
My scanner says that code is "Post Catalyst Fuel Trim Too Rich Bank 2"
Maybe it is different for the ford scanner but I would not think so.
(everyday truck)
2004 F250, 6.0l, 4x4, supercab, short bed, 6 speed
(play truck)
1990 F250, 351w turbocharged, Megasquirted, Spearco intercooler, BB GT 42, 5 speed, 4x4, 36x12.50's
dustymoran is offline
post #3 of 13 (permalink) Old 02-12-2007, 06:17 PM Thread Starter
Re: Code P2099???
Is there a code that refers to "UNDER BOOST ON TURBO"?
The service tech wrote it down, thats the number he gave me.
x-monitor
Air horns
cvucich is offline
post #4 of 13 (permalink) Old 02-12-2007, 06:23 PM
Re: Code P2099???
There is an overboost code wich is P0234
(everyday truck)
(play truck)
post #5 of 13 (permalink) Old 02-12-2007, 10:33 PM Thread Starter
Re: Code P2099???
Not that one either!! Anyone???
x-monitor
Air horns
cvucich is offline
post #6 of 13 (permalink) Old 02-12-2007, 10:56 PM
Btravelen's Avatar
Re: Code P2099???
P1247 Turbo Boost Pressure Low
P0237 Turbo Boost Sensor A Circuit Low Input
P02099 Post Catalyst Fuel Trim Too Rich Bank 2
You sure you have the right code?
'05 Excursion 6.0L with Air Lifts and Bilsteins, high idle mod., only 'tuner' is in the radio, towing an '00 HR Alumascape 31SKS with a Hensley.
Btravelen is offline
post #7 of 13 (permalink) Old 02-12-2007, 11:36 PM
FamilyRide's Avatar
Re: Code P2099???
I'll bet it's P0299. [img]/ubbthreads/images/graemlins/wink.gif[/img]
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #8 of 13 (permalink) Old 02-13-2007, 08:31 AM Thread Starter
Re: Code P2099???
Well let's say he wrote it down wrong and it is P0299, what is that code??
x-monitor
Air horns
cvucich is offline
post #9 of 13 (permalink) Old 02-13-2007, 05:56 PM
fordmastertech's Avatar
Re: Code P2099 or P0299???
The P2099 doesn't exist on a 6.0 so I would think the code must be a P0299. I would highly doubt any Ford dealer that works on the 6.0s hasn't seen this code. Most likely a sticking VGT turbo.
FMT
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
post #10 of 13 (permalink) Old 02-13-2007, 08:49 PM
can i ask what is a VGT??? thanks
tiger0432 is offline
post #11 of 13 (permalink) Old 02-13-2007, 09:23 PM
Variable Geometry Turbocharger (VGT)
FMT
post #12 of 13 (permalink) Old 02-13-2007, 10:39 PM
dccarling's Avatar
Most likely it's the turbo vanes sticking however it could be the exhaust gas backpressure sensor. I had the P0299 (turbo boost) code on my '06 at about 21,000 miles. The dealer first replaced the EGBP sensor and cleared the code which came back on the next day so the next trip to the dealer they replaced the turbo. 1500 miles later no check engine light and running fine.
2011 F-350 6.7 KR DRW 4x4, FX4, Black/Black Int. nav, 5th wh prep. goose neck kit, moon roof, tail gate step and most of the other options.
(wife's truck) 2012 F-250 6.7 Lariat 4x4, FX4, crew cab, SB, ultimate pkg, 3.55 elec. lock diff, 20" wheels, moon roof, chrome pkg. autumn red 2 tone ext, adobe int.
dccarling is offline
post #13 of 13 (permalink) Old 02-14-2007, 09:35 AM Thread Starter
I am just about where you were on mileage with my 06' when this happened. I will be taking it back to the dealer today with this info in hand.
Thanks guys!!!
x-monitor
Air horns
cvucich is offline
