code p2614 - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 01-28-2010, 09:00 AM Thread Starter
scrapin's Avatar
code p2614
P2614Camshaft Position Signal Output Circuit/Open
I am getting this code on my 6.0, can someone tell me what the issue is and where is it and how do i fix it?
2008 F250 XLT 6.4 40k miles 4x4, , 3/04' 6.0 F350XL PSD 4x4 dually dump, moog ball joints, 9' min. mt.2 fisher plow----- 2001 F250 5.4 liter gasser 4x4
scrapin is offline
post #2 of 7 (permalink) Old 01-28-2010, 09:25 AM
alexb's Avatar
That code is usually more of an effect than a cause. It can set during a hard start/no start or a stall event.
Ford Senior/Master/Diesel Technician in the Greater Toronto Area. Contact me for help getting your vehicle serviced. Do not contact me with anything pertaining to performance modifications. Proud to be a member of Ford Doctors Diesel Technician Society.
alexb is offline
post #3 of 7 (permalink) Old 01-28-2010, 09:42 AM Thread Starter
scrapin's Avatar
Havent been able to start it for a few days, and this code keeps popping up. I bought a cps and want to replace it. Any instrcutions on how to do this and where it is? I know its a ***** do, especially if i snap it!
scrapin is offline
post #4 of 7 (permalink) Old 01-28-2010, 12:00 PM Thread Starter
scrapin's Avatar
Desparate here! How do u get the cps out of the block! I got the bolt off but the thing will not budge
scrapin is offline
post #5 of 7 (permalink) Old 01-28-2010, 12:19 PM Thread Starter
scrapin's Avatar
ok now im screwed the dam sensor has snapped up topped!!!! Can i punch it in and hope it goes into the block and ends up in the oil pan!?? Need some serious help here!!
thank u
scrapin is offline
post #6 of 7 (permalink) Old 01-28-2010, 09:16 PM
alexb's Avatar
NO! You'll push it into the camshaft. It won't go into the pan. The only way you can get it out is to put a self tapping screw into it and CAREFULLY pry it out. A little heat with a small torch will help melt the o-ring, because that's likely what it's caught up on.
alexb is offline
post #7 of 7 (permalink) Old 01-29-2010, 09:17 AM Thread Starter
scrapin's Avatar
Had to get the pig towed last night. It's at a shop now and hopefully the guy will have some luck by getting it out in a couple of hours! I have had it with this truck, issue after issue with this thing and it only has 35k miles on it! Ill take a 7.3 all day long!
scrapin is offline
