Codes P2263 and P2623? - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 10-08-2005, 12:36 PM Thread Starter
Code P2263 I have had this happen around 3 times lately. I looked on the code chart and here is what it said.
(P2263) Turbo/Super Charger System Performance / MAP hose sensor, CAC system leaks, Intake leaks, EP sensor, exhaust restriction , exhaust leaks.
Also had this code once (P2623) Injector Control Pressure Regulator Circuit/ IPR circuit failure / Open/grounded circuit, stuck IPR, Loose connection.
So in a nut shell what does this mean to me?
Thanks......
[img]/ubbthreads/images/graemlins/tongue.gif[/img]
jobjohn is offline
post #2 of 3 (permalink) Old 10-08-2005, 12:49 PM
Re: Codes P2263 and P2623?
Look at Post 2003 F550 latest flash. I had the same code.
2008 F450 4x4 Lariat Job 3 05/14/08 build date
4:30 rear end
6.4 diesel 350 HP 650 Lbs Torque its on the valve cover sticker
Dark Stone Metallic/Pueblo Gold Metallic
Captain Chairs
Super liner spray in bed liner
Trailer Saver TS3 Air Ride Hitch
Extang Trifecta tonneau cover
last1stding is offline
post #3 of 3 (permalink) Old 10-08-2005, 04:33 PM
teamroper60's Avatar
With regard to P2263, it sounds like this TSB may apply to you:
2003-05 Various Running Problems, Check Engine Light; New EBP Sensor:
Trucks built before 1-17-05 that exhibit buck/jerk, hesitation, lack of power, stalling, stumble, black smoke, surging, rolling idle, changes in engine sound at idle or when driving at a steady speed, or with the trouble codes P2263 or P0299, may have an exhaust backpressure sensor signal that is incorrect or erratic. A revised EBP sensor is available if this is found to be the case. Part number 4C3Z-9J460-A. (edited and paraphrased).
As for the P2623, it sounds to me like you are suffering from the chaffed wiring harness issue. IIRC, the IPR wiring was in the harness that was chafing.
#43
President and Webmaster
teamroper60 is offline
