Cold Air Intake - Diesel Forum - TheDieselStop.com
Old 04-27-2009, 10:21 AM   #1 (permalink)
craiggo's Avatar
Cold Air Intake
Question for you all....
I have a late 06 and I was looking under the hood this weeked and noticed the intake sits righ behind a big metal or plastic shield (I think it's a bracket for the radiator or something). I'm thinking about drilling a few big holes in that shield so the intake can grab cold air from the front of the truck; much like the ram air set up I had on my 7.3. Has anybody else tried this? Woudl there be any benefit on the 6.0 (like there was on my 7.3)?
Also, how the hell does that front grill come off?
Craig
1990 F250 Banks Sidewinder/Ram air
E4OD Tranny w/3.55 Rear end
Ford repurchased my 2006 Ford F250 Superduty 4x4 Crew Cab, Lariat Package, Fx4 Package, 156" Wheelbase, 6.0l V8 Diesel, Torqueshift 5spd Auto Transmission, Dark Stone Metallic Clearcoat Exterior With Arizona Beige Clearcoat Metallic Two-Tone Accents, 3.73 Ratio Limited Slip Axle, 12.5k Trailer Hitch Tow Command System, Trailer Brake Controller, Line-X Bed Liner And 18" Polished Forged Aluminum Wheels.
Edge Insight
29' 2004 Wilderness Advantage Travel Trailer
craiggo is offline
Old 04-27-2009, 12:20 PM   #2 (permalink)
Strokin' 6.0's Avatar
Craig,
What you describe is the Zoodad mod (named after a board member). I did it to mine. The only thing I've noticed, after doing it, was a bit of a quicker spool-up on the turbo, but it is a very negligent increase. If you do it, make sure you put a mesh screen over the hole, to reduce the bugs committing suicide in your air cleaner.
The grill on my '04 comes off with phillips screws on top and a good yank.
Fred
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Reman'd 6.0L @43,956 miles
Reman'd Turbo @54,814 miles
Strokin' 6.0 is offline
