Cold start issues, please help. - Page 3 - Diesel Forum - TheDieselStop.com
Old 10-21-2009, 05:02 PM   #31 (permalink)
Strokin' 6.0's Avatar
I already know what wrong with it, though.
You ready for it?
IT'S A !!!!
Fred
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Reman'd 6.0L @43,956 miles
Reman'd Turbo @54,814 miles
Strokin' 6.0 is offline
Old 10-21-2009, 08:35 PM   #32 (permalink)
LocoMike's Avatar
Originally Posted by Strokin' 6.0 View Post
Too late on that, Mike, but no worries, I'm reading some good posts, which give me good ideas to suggest to the mech, when I see him. Of course, he'll look at me and say, "Well, since you seem to know it all, you fix it", and I'll shut up at that point.
Make sure your mechanic is aware of this FORD procedure:
My dealr tech said he had never heard of it
LocoMike is offline
Old 10-21-2009, 09:52 PM   #33 (permalink)
My 07 is at dealer right now for a cold start, rough running cold issue.
They found the FICM to be bad and are replacing it (under warranty), should get it back tomorrow, we'll see if they got it solved.
Doug
2007 F-350 Crew Cab DRW 4X4 4.10LS, MBRP 4" Cool Duals turbo back, SCT/ custom tunes from Elite Diesel, Autometer gauges EGT, Trans, Fuel Pressure, MSD Dash hawk OBD II reader for ECT,EOT,Voltage and Boost, Dieselsite coolant filter
dougjpr is offline
Old 10-22-2009, 02:47 PM   #34 (permalink)
Mike, thanks for the .pdf...I'll hand it to the mech.
Went out today to start the truck, after it had been plugged in....now it doesn't start at all....it still turns over, but it just doesn't fire anymore.
FICM?
Injectors?
HPOP?
ICP?
Who the hell knows? I'll find out November 6th.
Fred
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Old 10-22-2009, 10:22 PM   #35 (permalink)
LocoMike's Avatar
[quote=LocoMike;1797339]
Originally Posted by King Rancher View Post
Humm, it's got me thinking. It is a fact that pressure is not an indicator of viscosity (flow).
Ford has my truck right now and is charging me $ 150 for just a diagnoses (I am totally out of ideas) and that is after $ 126 for a total reflash
Make ya a deal......
Report back on your oil change and I will report back on what Ford says.
Glad I have my AE to weed out what I expect them to say
Well after 3 days at Ford dealer and $300 later it is worse than ever. They reflashed all the modules with the latest Ford software and spent 2 hrs on the Ford IDS system.
Basically they said we don't know what it is and can't fix it cause your EGR delete is screwing up thier diganostic software.
I paid the bill, grabbed the keys and ran like hell.
I am changing back from Rotella Synthetic 5W-40 to straight mineral based Rotella) tommorow. reason being is beacuse it is the ONLY thing that has changed since 03 with no symptoms..............................
Has anyone had any troubles with the Synthetic Rotella 'Diesel' ????
LocoMike is offline
Old 10-22-2009, 10:29 PM   #36 (permalink)
teamroper60's Avatar
No. And I doubt it is your problem either, since it normally helps with the very symptoms you are experiencing. I still believe it is an injector issue.... Sticking spool valves, scored plunger and barrel, something like that....
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 10-22-2009, 10:31 PM   #37 (permalink)
LocoMike's Avatar
[quote=LocoMike;1798117]
WELL........ NEW INFORMATION:
I drained the Synthetic Rotella 15W40. REPLACED with Motorcraft 15W40.
The truck started with no problems (but it was above 70 outside today). I will report back when it is a "cold start", basically below 50 F.
Still have problems at WOT (lots of BLUE smoke) but I am working on that.
LocoMike is offline
Old 10-23-2009, 01:05 AM   #38 (permalink)
King Rancher's Avatar
Send a message via Yahoo to King Rancher
[quote=LocoMike;1798122]
So it is an improvement .. I am glad it actually did something in the right direction. Evryone on here was kind of cutting me down about it, except for you LOCO .. thanks and I hope it actually works.Its amazing that thin(synthetic) oil flow might be the cause of it. and incase you are under warranty(100,000 engine) don't tell your dealer you were running synthetic, because depending on how hard up they are they might call you out on that if something happens. by the way, where you from. your having weather like me. I am in Tennessee
2006 Ford F-250 King Ranch, Crew Cab, FX4, 6.0 powerstroke diesel, 20" wheels, 35" Kumho a/t, Bully Dog 150hp extreme. Do It Like It's Your Last Time !
King Rancher is offline
Old 10-23-2009, 07:40 AM   #39 (permalink)
mmterrill's Avatar
hey dougjpr how was your truck acting when you took it in. when the ficm is bad how does your truck act or does it not start at all? thanks.
mike
mmterrill is offline
Old 10-24-2009, 01:15 PM   #40 (permalink)
LocoMike's Avatar
[quote=King Rancher;1798190]
sorry again for highjacking the post
Thanks to all !!! Sure is nice to have folks to run things by and all of your input is really apprecciated.
My 'theory' is the Rotella SYNTHETIC was foaming. I love Rotella oil and ran it for 130K miles in my prior 7.3. Just think there was a problem with the anti foaming additives in the Rotella Synthetic. There was an immediate change when I went back to the Motorcraft oil. Please don't turn this into 'an oil war forum', just relating to MY 6.0 fiasco.
I use an AutoEngenuity program and my DESIRED Injector HPOP gets matched by the ACTUAL HPOP pressure so I rule out pump, leaks and regulator.
My AE Tool just datalogged that under high RPM (injectors firing fast) the main power from the FICM is dropping down to 46 Volts. Ford spec calls for 48 to 50 volts. FYI... my problem now is a stutter/stumble/ misfire with no codes anytime above 2500 RPM. aka FICM working harder/firing faster.
I am now looking for the best price on a NEW FICM to obatin, get flashed then send to Inovvative for the custom program.
I am still open to all the good ideas and info you folks send my way !!!!!
AND PLEASE DON'T FORGET THE GENTLEMAN WHO BEGAN THIS POST
Cold start issues, please help.-ficm-power-2500-rpm-.jpg   Cold start issues, please help.-ficm-wot.jpg
LocoMike is offline
Old 10-24-2009, 05:17 PM   #41 (permalink)
LocoMike's Avatar
[quote=LocoMike;1797356]
__________________________________________________ ______________
NEW INORMATION:
After 3 days at Ford dealer and $300 later it is worse than ever. They reflashed all the modules with the latest Ford software and spent 2 hrs on the Ford IDS system.
I am changing back from Rotella Synthetic 5W-40 to straight mineral based Motorcraft tommorow. Reason being is beacuse it is the ONLY thing that has changed since 03 with no symptoms.......................
NEW INFORMATION:
My 'theory' is the Rotella SYNTHETIC was foaming. I love Rotella oil and ran it for 130K miles in my prior 7.3. Just think there eas a problem with the anti foaming additives in the Rotella Synthetic. There was an immediate change when I went back to thee mororcraft oil. Please don't turn this into 'an oil war forum', just relating to MY 6.0 fiasco.
I use an AutoEngenuity and my DESIRED Injector HPOP gets matched by the ACTUAL HPOP pressure so I rule out pump, leaks and regulator.
My AE Tool just datalogged that under high RPM (injectors firing fast) the main power from the FICM is dropping down to 46 Volts. Ford spec calls for 48to 50 volts. FYI... my problem is now a stutter/stumble/ misfire with no codes anytime above 2500 RPM.
I am now looking for the best price on a NEWFICM to obatin, get flashed then send to Inovvative for the custom program.
LocoMike is offline
Old 10-24-2009, 05:49 PM   #42 (permalink)
No buzzing sound
Normally, when I KOEO, I hear a buzzing sound for a second or two, which is the Injector Electrical Self Test. Today the weather is warmer, so I went out to see if the truck would start.....no buzzing noise=no Injector Electrical Self Test.....
=FICM is dead?
Fred
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Old 10-24-2009, 06:37 PM   #43 (permalink)
LocoMike's Avatar
=FICM is dead?
Check the fuse. Your FICM could be dead (should be 48 to 50 vdc) output if recieving battery voltage input. Or....... your fuse could be blown. Of course a bad FICM could blow the fuse as well !!!
Here is a schematic........
LocoMike is offline
Old 10-24-2009, 07:57 PM   #44 (permalink)
Checked all three FICM fuses...#20 and #103 under the dash are okay, and the 10a mini fuse under the hood is okay too. I ran the dash test....oil pressure is 235psi after cranking, fuel pressure is 49psi, the tach is over 100rpm when cranking, batteries are 11.9v when cranking and 12.65v when not cranking.
Indications, in my opinion, are leading to the FICM. The lack of injector buzzing is telling me that there is no electricity going to the injectors=dead FICM, I think.
Fred
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Old 10-24-2009, 08:03 PM   #45 (permalink)
Not sure what oil pressure the "dash test" is capturing but it is either way low for the HPOP (needs to be at least 500psi to start) or way high for the low pressure side...
pics
#43
