COLD WEATHER SURGING - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 02-09-2011, 04:26 PM Thread Starter
When the temperature outside is around 45 or lower when the engine is cold my truck surges for abotu 20 seconds then it evens out and runs smoothly. when I use the block heater there is no problem. Any ideas on what could be causing the surging problem. FYI, I am going to have the egr delete kit installed and a bigger oil cooler installed in a week. I have 86000 miles and it a 2003 model.
jackcu is offline
post #2 of 9 (permalink) Old 02-09-2011, 05:18 PM
By "surges" do you mean the idle speed rises and falls irratically for the first 20 seconds or so? That is fairly typical cold-start behavior for older engines. What oil are you using?
2004 F-250 Lariat CC, Short Bed, 4x4, 6.0L, TorqShift, FX4, Metallic Green/Arizona Beige, Medium Parchment Leather, Fumoto, B&W Turnover, A.R.E. LSX Tonneau, Built 4/01/04
MoeB is offline
post #3 of 9 (permalink) Old 02-09-2011, 05:18 PM
mwilbur516's Avatar
What kind of bigger oil cooler?
06 F250 XL, FX4, Upfitters, TBC, 15% window tint, 3.73's, Muffler delete, Cat delete, Fumoto valve, High idle mod, Zoodad mod, Harpoon mod, CCV mod, ARP studs, SCT Livewire w/ Looney Wild DD Tune, Dieselsite.com coolant filter, Glow Shift Fuel Pressure Gauge, Ford Blue spring upgrade, 6.4l Banjo Bolts, Upgraded turbo boots, Upgraded HFCM drain plug, Quick Tricks 58 volt FICM, S&B CAI, Monitoring EOT, ECT, EGT, IAT, Voltage and RPM
Horsepower is like a gun; You may not always need it, but it's nice to know its there
mwilbur516 is offline
post #4 of 9 (permalink) Old 02-09-2011, 06:13 PM
My truck was acting similar along with having a little bit of a miss when it was cold. Dealer replaced the FICM half shell under warranty and that seems to have solved the problem at the moment.
06 F350XL rc,lb,manual 4x4, 6.0 PSD, 6 speed
Upfitter Switches
BCP Idle Control
55 watt halogen back up lights (4)
200 psi 5 gallon air system
Diesel Site Coolant Filter
HELLA FF50 Fog Lights
Custom Headache Rack
Custom Shovel Rack
Weatherguard Saddle Box
Weathergaurd Wheel Well Box
Herculiner wheel wells and rocker panels
Edge Insight with EGT and Fuel Pressure
MattShade is offline
post #5 of 9 (permalink) Old 02-09-2011, 06:18 PM
It is varnish building up in the oil side passages of the injectors. Hot shot secrets is the product you want to use to clean up that varnishing.
Eric
2004 Ford Excursion Limited
4X4, 6.0, 1/2004 Build date
Solid Black, Secret Service Look alike
Stock engine w/ EGR Delete
4" turbo back exhaust w/ Deleted Cat
2004 Ford F-250 King Ranch
4x4, 6.0, 2/04 Build Date
Chestnut Brown Metallic
Stock engine with EGR Deleted
SCT Livewire TS from Innovative Diesel
2003 Ford Excursion Limited (Totaled 5/1/2015)
4X4, 6.0, 2/2003 Build date
Bone stock at this point
Very few issues over its life...
knightgang is offline
post #6 of 9 (permalink) Old 02-09-2011, 06:23 PM
Injector varnishing makes them stick when cold. Put in hot shot secrets. It will clear it up.
Eric
post #7 of 9 (permalink) Old 02-09-2011, 07:22 PM Thread Starter
Sorry had to step out for a while. I am replacing the stock oil cooler with one that has bigger coolant passages due to the ford coolant plugging up the egr and oil coolers.
jackcu is offline
post #8 of 9 (permalink) Old 02-09-2011, 07:23 PM Thread Starter
Thanks for the replys. I really like this site so much good information.
jackcu is offline
post #9 of 9 (permalink) Old 02-09-2011, 07:24 PM Thread Starter
Can I get this "HOT SHOT SECRETS" at any auto parts store?
jackcu is offline
