coolant - Diesel Forum - TheDieselStop.com
Old 03-12-2010, 12:05 PM   #1 (permalink)
coolant
All,
I have been using ZEREX G05 coolant in my 6.0L & my 4.0L Jeep.
BUT
The hardware store chain that supplied it dropped it from thier line.
I went to NAPA online, told them I had a 6.0L powerstroke
AND
they recommend PRESTONE EXTENDED LIFE part number PAF AF2000.
NAPA claims it it a direct replacement for GO5.
Anyone using PRESTONE ?
ANY TROUBLES ?
Would PRESTONE require an additive pkg for diesel like VC8 ?
I am preping for my first cooling system flush & fill.
questions - questions - questions
~thanX!!!
~Mack
~Mack
Hayward, Ca
sillsmack@neteze.com
03 F350 SC FX4 SRW 6L 5SP
03 Jeep Wrangler Sport
sillsmack is offline
Old 03-12-2010, 01:39 PM   #2 (permalink)
OT
OT's Avatar
Mack..does prestone coolant meet fmc WSS M97B51 A1 ASTM D3306. If not, find zerex GO5 or get gold at . Recently talked about, so just go thru few back pages. Good luck.
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 03-12-2010, 09:38 PM   #3 (permalink)
Btravelen's Avatar
When I'm out of warranty, I'm going to flush and refill with the red ELC that Navistar uses in the VT365. All reports are that it's a MUCH better coolant, and that the only reason Ford used the G05 is that it's fleet compatible.
Take Care
'05 Excursion 6.0L with Air Lifts and Bilsteins, high idle mod., only 'tuner' is in the radio, towing an '00 HR Alumascape 31SKS with a Hensley.
Btravelen is offline
Old 03-12-2010, 09:59 PM   #4 (permalink)
AND
They are giving you incorrect info but NAPA should have Zerex G-05 coolant.
That Prestone stuff will work if you add some DCA-4 or DCA-2 to it. G-05 already has DCA-2 in it.
444-4D is offline
Old 03-12-2010, 11:18 PM   #5 (permalink)
Strokin' 6.0's Avatar
Take Care
It's what I use in mine...no problems yet.
Fred
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Reman'd 6.0L @43,956 miles
Reman'd Turbo @54,814 miles
Strokin' 6.0 is offline
Old 03-13-2010, 12:37 AM   #6 (permalink)
teamroper60's Avatar
Same here. I've been running it for about a year now.
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 03-13-2010, 07:49 AM   #7 (permalink)
what makes the red ELC better ?
longer change interval ?
more efficient heat exchange ?
anti corrosive properties better ?
2006 F350 4X4 6.0L Lariat Crew Cab FX4 SRW
Edge Insight with EGT probe
Autometer Fuel Pressure Gauge / ITP Adapter Line
DieselSite Coolant Filter
Amsoil EaBp 100 ByPass Filter
Ford Fuel Pressure Blue Spring Kit
ITP HFCM Brass Drain Plug
Fumoto oil drain valve
born 10/2005, in service 8/2006
bought by me Jan 27th 2010 with 54K miles from first owner; Bill, RIP.
just rolled 110K miles DEC 29th 2011
willingtonpaul is offline
Old 03-13-2010, 08:34 AM   #8 (permalink)
I am also interested in the specific properties that cause people to say it is better. I know one of them that people quote is 150k miles between changes/flushes. I am leary about that being achievable without some downsides to protection in the "real world" application.
Mark
bismic is offline
Old 03-13-2010, 11:22 AM   #9 (permalink)
In our application, the change interval is 300K or 600K with a specific "booster" at 300K (provided you use distilled water of course) in OTR use, 600K is the change interval and stretched even further with the "booster".
The boiling point is higher. I can't remember off the top of my head what the difference is but I did compare them when I had bottles of each available to me.. For some reason, 12 degrees sticks in my mind but I will not swear that is correct.
Anti-corrosion I can't really speak about because I do not know. But I feel very certain it is at least as good (after all, it is supposed to last 300K)...
Finally, it is also the factory fill in the VT365 (the IH version of our engine).. If it is good enough for IH, it is good enough for me...
pics
#43
Old 03-13-2010, 03:57 PM   #10 (permalink)
Last Question
Thank Guys, that's some good info.
My Last Questions about G05 is this.
First Read what I found on the G05 website-->
_________________________________________
Valvoline’s Zerex G05 antifreeze coolant is a long life
Fully formulated ethylene glycol-based fluid suitable for
Passenger cars, light trucks and heavy duty vehicles.
The formulation is designed for both gasoline and diesel
engines. It’s lower silicate, reduced pH, phosphate free
European technology Protects all cooling system metals,
including aluminum, from corrosion.
ZEREX G05 IS A NITRITE CONTAINING COOLANT
DESIGNED TO PROTECT DIESEL ENGINE CYLINDER
LINERS FROM CAVITATION.
It contains deposit control additives for protection from hard water
Deposits and scale. The ASTM and other test data shown on this
Sheet reflect the high performance corrosion inhibitor package
After reading the part I put in BOLD & underlined, I read that as to mean
no cooling systems additives are necessary for the 6.0L.
Am I correct ??
~thanX!!
~Mack
~Mack
Hayward, Ca
Old 03-13-2010, 06:58 PM   #11 (permalink)
69cj's Avatar
Am I correct ??
~thanX!!
~Mack
I agree and that is why I will stick with the GO-5 or Premium Gold.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 03-13-2010, 07:30 PM   #12 (permalink)
OT
OT's Avatar
updated coolant check says..if test strip indicates nitrite level is between 300-800ppm add 32oz of supplemental coolant additive m/c VC8. If below 300ppm flush system with iron cleaner VC9. Nothing if nitrite level over 800ppm.
OT is offline
