coolant cap relacement - Diesel Forum - TheDieselStop.com
Old 05-03-2005, 10:57 PM   #1 (permalink)
Hello, 1st post. I have a 2004 f250 lariat crewcab, it has a tendency to blow coolant if I really hammer it. I found a coolant cap at autozone today that fits great and is rated at 18 psi. will it cause any problems to use this cap in hopes of decreasing coolant loss. Would this allow excessive pressure on the headgasket. Standard cap is rated at 16 psi.
F-250/2004, true bule/arizona beige crewcab,engine built 09/03. AFE stage2with proguard-7/ innovative's sct extreme tune, donnahoe racing 4.5" lift/ banks technicooler/ weld evo velociti XT 8, 17x10/toyo opencountry AT 325-65-17/ excursion center console with rear cup holders and woodgrain lid/ molded woodgrain dash cover/ DDX7015/ flipdown 7" rear screen/ JL audio stealth box/ JL 300/4/ and JL 500/1 custom 10" behind the seat ported sub box/ tracvision A5 (coast to coast direcTV)/ Viper 791XV/ motorola professional handsfree system/ line-X bedliner
tedshields is offline
Old 05-04-2005, 12:09 AM   #2 (permalink)
Banned
Re: coolant cap relacement
If your truck is still covered under the engine (100,000 mile) warranty, I would suggest that now is the time to have any coolant loss concerns addressed properly rather than trying to mask any symptoms until you have to write the cheque...
If it blows coolant with a 16 pound cap, I can't see an extra 2 pounds making anyone happy (other than AutoZone, that is).
GrampyJim is offline
Old 05-05-2005, 10:13 AM   #3 (permalink)
tedshields
If you can replicate it blowing coolant, than I would put the original cap back on and get the dealer to fix it. While it is still under warranty. My dealer gives a loaner vehicle under the 36,000 mile warranty, not sure if he does on the engines 100,000 mile warranty and you'll save the $100 deductable.
Good Luck
TasMan
2004/04 Engine,King Ranch,F-250,4x4,SWB,3.73 LS, Adjustable pedals,Reverse sensor,Moon roof,clearance lights, Power rear window,Heated seats,Bedliner, DPPI T-409 Turbo Back, AFE Pro-Guard7, C-Bet'r mirror, Fumoto drain valve, AIC, Extange Tonneu, Lund SS Interceptor, Siver Star Bulbs, Harpooned tank, SUV double wiring harness, Bright Box, Clifford RS 3.5 alarm, 3" Edge Plush Ride, Bilstein Shocks, Westin Sportsman CPS Grille Guard, XM Commander wired in with a PIE Adapter, Eagle 137 series rims and Bridgestone Revos 285/75-16, Husky Liner Mud Flaps.
http://community.webshots.com/user/tasman3721 UpDated 27 October 2005
Retired Chief Warrant Officer 4
tasman is offline
