Coolant Filter Kit Recommendations Please - Diesel Forum - TheDieselStop.com
Old 05-05-2010, 06:19 PM   #1 (permalink)
Looking on ordering a kit and was wondering what feedback you guys can give on which kit to order and why.
Thanks!
hyvltge is offline
Old 05-05-2010, 07:46 PM   #2 (permalink)
Coolant filter
I ordered a coolant filter from Dieselsite. Easy install and reasonably priced. Also order extra filters, 1 every 3 months (unless plugged) for first 9 months then 1 a year afterwords.
blackshadow69 is offline
Old 05-05-2010, 08:36 PM   #3 (permalink)
MikeL46's Avatar
My Photos: (14)
As far as I can tell all the kits are fairly similar. Some include things that are options at other sites, so pay attention to what you are ordering.
No matter which one you get, make sure you get the ball valves that shut off the flow so you can change the filter without losing excess coolant.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 05-05-2010, 08:56 PM   #4 (permalink)
Supporting Member
my03psd's Avatar
Dieselsite for me too!!
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
Old 05-05-2010, 09:11 PM   #5 (permalink)
Dieselsite here also, clean install + it looks good.
2 stroker
2 Stroker is offline
Old 05-05-2010, 09:19 PM   #6 (permalink)
Dieselsite here as well , I got the e series kit that mount down on the frame rail. Quite happy with it , allowed me to install oil bypass up top .
Kemp3 is offline
Old 05-05-2010, 09:27 PM   #7 (permalink)
Dieselsite for me too. Very easy/clean install, as mentioned, don't forget the valves. You might want to order some extra filters too. The first 2 filters are changed fairly quickly.
Doug
2007 F-350 Crew Cab DRW 4X4 4.10LS, MBRP 4" Cool Duals turbo back, SCT/ custom tunes from Elite Diesel, Autometer gauges EGT, Trans, Fuel Pressure, MSD Dash hawk OBD II reader for ECT,EOT,Voltage and Boost, Dieselsite coolant filter
dougjpr is offline
Old 05-05-2010, 10:38 PM   #8 (permalink)
teamroper60's Avatar
I got mine from DIESELSITE but there are several others and as MikeL46 pointed out, aside from things like ball valves, they are all basically the same. Any of them will do. Just pick the one that you like best or best suits your budget.. And yes, get the ball valves. They are really nice to have when it comes time to change the filter...
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 05-05-2010, 10:39 PM   #9 (permalink)
I have the Dfuser kit and it is very nice as well. However, I was going to originally order Dieselsites kit but called them last Friday and found out that they are backordered for 2-3 weeks. So take that into consideration if you are planning on purchasing one soon. Either kit is good and the Dfuser comes with everything you need in one package: Ball valves and 3 baldwin filters.
montemx is offline
Old 05-06-2010, 01:04 PM   #10 (permalink)
los
los's Avatar
I will be getting the dieselsite one soon, its a better option price wise for me.
los is offline
Old 05-14-2010, 01:00 PM   #11 (permalink)
DIESELSITE here! Great looking and functioning product! Value-Added, you can call and get great service. Had minor issue, resolved in one phone call. Not a commercial, good people.
Ken
2006,F-250 FX4,C/C,Lariat,6.0 PS w/ Auto & 3:73, Dark Satin Green/ Arizona Beige, Zoo-Dad, Diesel Site Coolant Filter, Accu Fab Elbow, Ford-Blue Spring FPR Upgrade, Muffler Delete, Nitto Terra-Grapplers AT 33's
Muddog06 is offline
Old 05-14-2010, 08:47 PM   #12 (permalink)
paintingman's Avatar
Here is a example of a NAPA filter setup on my truck And the other is a racor on my buddys F550 4x4
Coolant Filter Kit Recommendations Please-truck-pictures-014.jpg   Coolant Filter Kit Recommendations Please-truck-pictures-008.jpg
_________________________
2004 F250 6.0 PSD every day work truck
Jotto desk / laptop / printer for giving estimates
3000 watt inverter keeps drill batteries charged
4" tubo back MBRP cool duals
CFM+ intake elbow / Airaid cold air intake
SCT X3 from innovative diesel
Coolant Filter / Amsoil by-pass system
ATS Intercooler
Fluidampr / 200 amp alternator
ARP head bolts / Black onyx head gaskets
185cc Injectors 70hp+ / stock turbo
stage 1 fuel lines / cross over with fixed orifice
58 volt FIMC mod from swamps diesel
Airdog 2 with in tank fuel module upgrade Mag-Hytec Diff. and trans. covers
Aluminum degas tank
paintingman is offline
Old 05-14-2010, 08:57 PM   #13 (permalink)
EnCMerk's Avatar
paintingman, I see you used a four line filter base. Where do all your lines go ? Most setups I've seen only use 2 lines. Thanks for the pics. Looks like a job i want to do also.
"Moby Dick" 2005 F350 2wd CC SB PSD. All stock. ScanGauge II with custom (homemade) mirror mount. Self installed heated seats. $4.00 high idle mod. Planned upgrades: 4" turbo back MBRP exhaust, coolant filter, ARP studs.
Pulls my 2007 Thor Wave 25' travel trailer like it ain't even there.
EnCMerk is offline
Old 05-14-2010, 09:13 PM   #14 (permalink)
the white one is a racor filter he got off eBay. The Housing is full flow with small passages that bleed of small amounts of coolant at a time and send it out the other side. so the heater hose go's in one side and out the other and back thru the heater core. Mine is the NAPA and Amsoil fiters on the same bracket
ATS Intercooler
Aluminum degas tank
Old 05-14-2010, 09:16 PM   #15 (permalink)
EnCMerk's Avatar
Thanks for the info!
EnCMerk is offline
