Old 11-05-2009, 09:47 PM   #16 (permalink)
Originally Posted by pigsbreath View Post
Acustrip makes test stips to test your glycol nitrates and freeze point.
$5.67 for 4 test strips delivered.
http://www.acustrip.com/CTS-3_Retail_Order_Form.pdf
Acustrip - Products
BTW - the key test is for NITRITES!
Mark
'06 F250, CC SB ESOF FX4 Lariat 3.73LS, 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; Racor CCV filter
Fumoto valve; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; Britebox; DashDAQ
Quadzilla recon XZT Fuel Pressure; BB mod
Synchromax in transfer case; Reflashed
Line-X, CPOhighway Prod. tool box; tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
Updated EGR valve; PIE adapter; 24" wiper blades
bismic is offline
Old 11-05-2009, 09:55 PM   #17 (permalink)
No harm done. I thank you for questioning me.
Bismic: My coolant temperature / oil temperature has been approximately 7 - 9 deg different running unloaded on level ground at 65mph. Do you think I should redo my flush with VC-9 to get as much coolant / rust residue out of the system as possible? Especially to remove any deposits from the oil cooler.
Cody
steel10 is offline
Old 11-05-2009, 10:06 PM   #18 (permalink)
Cody
I had the same question to answer for myself. At 50k I flushed the system without the VC9. I decided I would not re-do it MAINLY because I have a coolant filter and the last 3 filter changes did not have much solids. Also when I drained the fluid the first time during the flush procedure, I did not see any solids.
Do you have a coolant filter? Did you see any solids during any of the drains?
Your temperature differential does not seem too bad to me. Have you ever seen it over 15 *F - even before the flush?
Mark
bismic is offline
Old 11-05-2009, 10:13 PM   #19 (permalink)
It seems like some are getting confused by my procedure. The last flush left 15.5 quarts of distilled water in the system when the pet**** quit draining. I then added 2 gallons (8 quarts) of pure Ford Gold Antifreeze.
8 quarts/15.5 quarts = 52% Antifreeze / 48% Water
I continued filling the coolant reservoir with a 50/50 mixture of Ford Gold Antifreeze and distilled water until the reservoir was full.
I checked my freeze protection using a coolant tester and it indicated that I was slightly over a 50/50 mix as was indicated by the freeze protection of ~-42deg F. A true 50/50 mix will yield a -34deg F freeze protection.
Cody
I think your reading with the coolant tester is correct. You will really never get all the antifreeze out of there... You calculations are not correct though.
50/50 is: half the capacity of the coolant system is water and the other half is straight antifreeze. Not 50% of the water left in the engine after you drain the radiator (thats where you got your 52/48 - 8 divided by 15.5). If you have 15.5qts of water and only 8qts of coolant you have 29.09% coolant in there (but there is still some old coolant in the "clear" water). It is essentially 50/50 of the 27.5 quarts not 50/50 of the 15.5 quarts.
Did you run the heat when you were heating it up? If not then you still had old coolant in your heater core.
2005 F250 LARIAT CC 4X4 6.0L PARROT CK3200 bluetooth car kit, Shaker 500 system, nice set of train horns, twin viair compressors and 5gal tank, 5" MBRP turbo back, AFE stage II intake, SCT tuner.
1996 F350 AT, IDM and switched ICP mod
1995 F250 SC AT, IDM and switched ICP mod, 6" susp 2" body lifts.
1994.5 F250 SC 5spd 4x4 IDM and ICP mod
bondsman is offline
Old 11-05-2009, 10:36 PM   #20 (permalink)
Bismic:
I have a coolant filter. I changed the filter after my flush / refill procedure. I didn't see any sediment / deposits coming out while draining nor in the filter when I cut it apart. Since I didn't see any deposits and my EOT / ECT hasn't varied by more than 7-9 degrees, I do not think I will redo and flush with the VC9.
Thanks,
Cody
steel10 is offline
Old 11-06-2009, 07:45 AM   #21 (permalink)
Thank you bondsman, I was just getting ready to do that. Also, are you testing the coolant in the tank? As the 50/50 concentration that you last put in may not be mixed with the rest of the coolant yet; you should test it from the pet****. Not to Hi-Jack but since so many people are watching this thread, what kind of filter systems do ya'll like best? And to help me not be an anal retentive ass what's the most efficient, quick and dirty way to change coolant if you plan on doing it every year. Thanks in advance, Eli.
grandpas97 is offline
Old 11-06-2009, 04:31 PM   #22 (permalink)
Originally Posted by 24hrsparkey View Post
I just had a re placement thermo stat + a power flushing , by the dealer. ( now there is a good chance i will have heat .
The dealer worksheet / invoice states they put in 2 gallons of gold.
I was thinking thats not enough , not sure.
New NAPA anti freeze tester. Hey it was $9 and i wanted to know about my freeze protection situation
Tested from pet**** into small clean container Yelded freeze protection to minus 35-45 F
So i guess i'm good to go , and the dealer may have done it correctly. Corrosion protection and exact pure coolant percentage vs water , i dunno. At least it will not freeze.
I did a small container of 50-50 mix while i had my handy dandy tester out , just for giggles. 50-50 yielded -25F protection But most likly would not have the corrosion protection that seems nessisary in these engines.
thats all i know about that.
24hrsparkey
Stock 03 250 SD 2door 4x4 p/u
6.0 June 03 Build Date
87,000 miles
E-017 flash
Muff Delete pipe , otherwise Stock
AND
2000 f350 ccab 4x4 , nice BIG truck that lumbers right along. Only 100,000 miles on it.
24hrsparkey is offline
Old 11-06-2009, 09:01 PM   #23 (permalink)
bigwhite1's Avatar
My apologies - I did not read it that way. Good job!
your math should be 8qts out 27.5 not 8/15.5. if you take 15.5/27= 57% water and 43% antifreeze.
2006 diesel,lb,cc
2004 cardinal 35ts
bigwhite1 is offline
Old 11-06-2009, 09:38 PM   #24 (permalink)
Removed my original math and redid it because you are correctd and I must have been brain dead .......
He left 15.5 quarts of water in and added 8 quarts of pure antifreeze. That now makes 8 quarts out of (15.5+8) or 8 out of 23.5 - that is 35%. Topping off w/ a 50/50 will never get you to a 50% concentration. Topping off w/ 100% will get you to the 43% you mention.
Mark
bismic is offline
Old 12-09-2009, 08:22 AM   #25 (permalink)
Guys please answer his question what about the VC-9 Iron cleaner.
And can you get it at NAPA.
Question: I didn't use the VC-9 iron cleaner. Do you guys think that I need to repeat the flushing process illustrated above but use the VC-9 to clean the internal coolant passages as well as the oil cooler?
Jayco1c is offline
Old 12-09-2009, 09:28 AM   #26 (permalink)
69cj's Avatar
The only place I found the VC-9 was at dealer. $26.50 per qt. 2 needed. As for repeating I cannot answer that since I have no idea the condition of your system. The only reason I went with the expense is the tech at the local dealer said that he always uses it and it is a Ford recommendation if not a requirement. Ford did say to use it in the letter that they sent me on nitrates.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 12-09-2009, 09:38 AM   #27 (permalink)
When did our society get so scared of offending someone that PET**** has to have letters blanked out?
Main Entry: pet·****
Pronunciation: \ˈpet-ˌkäk\
Function: noun
Etymology: pet- (perhaps from petty) + ****
Date: circa 1864
: a small ****, faucet, or valve for releasing a gas (as air) or draining
2004 F-350 Lariat CC LWB 6.0 PSD, DRW, FX-4 4x4, 4:10 Born 06/04 bought BRAND NEW on 10/26/04 Woo HOOOO This truck ROCKS!!! No mods yet,and it seems none NEEDED!! Replaced transmission @ 37k miles and EGR valve @ 58k miles : 92,000 miles as of Nov 2009
and
1996 F-250 SC 7.3 PSD, SRW, 4x4, 4:10 gears, bought new in May 96, TyMar Intake(on@150,000),Updated Turbo inlet hoses and breather assy,TrueCool 24,000 Tranny Cooler, Diamond Eye DP/Exhaust,Eviscerated Kitty,FPR Shimmed w/BB,Autometer z-series guages (boost, Tranny Temp, post turbo Pyrometer).Replaced Water pump @ 100,000.Rebuilt Tranny @ 140,000.Replaced GPR and Glowplugs at 159,000.Replaced brake vacuum pump 162,500.StanCor Heavy Duty GPR,4R100 tranny pan.Replaced starter @ 185000 miles : 205,000 miles as of Nov 2009
Powerstroke3302 is offline
Old 03-04-2010, 10:16 PM   #28 (permalink)
stoverbro's Avatar
confused....
Ok ive read this whole thread 3 or 4 times.
If the coolant capacity of the truck is 27.5 quarts and the mix is to be 50/50, then doesnt that require 13.25 quarts of coolant?
50/50 means half water and half coolant. Therefore 13.25 quarts water, 13.25 quarts coolant.
correct?
2003 F-250 6.0 Crew Cab 4x4 Lariat
1997 Camaro Z28 Convertible
1949 Chevy Thriftmaster pickup 355 stroker....
stoverbro is offline
Old 03-04-2010, 10:17 PM   #29 (permalink)
stoverbro's Avatar
sorry i meant 13.75 and 13.75
Old 03-04-2010, 10:58 PM   #30 (permalink)
ford_doctor's Avatar
You are missing an important reason for using the flush on any diesel engine. The flush most importantly removes what is left the depleted and broken down protective layer that forms on the cylinder walls and other metal surfaces inside the cooling system. Once the system has been cleaned installing the correct coolant containing the SCA will allow a fresh layer to form providing continued protection from corrosion and cavitation erosion.
The coolant filter systems are not a bad idea and they do remove the debris from the system but you still need to service the system chemically. It is not wise to skip the flush.
Ford Master Diesel Technician
Diesel Technician Society
ford_doctor is offline
