Coolant Leaking from Muffler - Diesel Forum - TheDieselStop.com
Old 06-02-2008, 03:10 PM   #1 (permalink)
When I fill my degas bottle to the Min line, I intermittently have lost level, get the white smoke, & when I park the truck I have coolant steadily dripping from my muffler weep hole. Problem is that it only happens about ever 8-10 times that I fill the degas bottle. Once the level drops so my degas bottle is almost empty, it maintains the level & doesn't lose anymore coolant. I have no visible signs of leaking antifreeze operating temperature issues, even under heavy load.
I did the jack the truck up, check for coolant @ the egr valve & I don't have any.
So what other path can the coolant get from the cooling system to the muffler?
I am out of warranty, called the dealer & they want to replace the egr cooler, egr valve, oil cooler, degas bottle & flush my cooling system.
I asked if they could diagnose the precise problem vs just replacing random parts that it might be
They told me that they would start by replacing these parts because it fixes most of the coolant problems, then if that didn't fix the problem, they would further investigate.
That is great and all under warranty, but this is my nickel. No mods of any kind.
04 F250 6.0 FX4 CC
BRUMFIJW is offline
Old 06-02-2008, 03:35 PM   #2 (permalink)
Why would you see it? It's leaking from the EGR cooler into the exhaust most likely.
2005 F-350 LARIAT 6.0 PSD SRW AUTO FX4 (removed) CC SB White, International emblems, Tow Command, Upfitters, Line-X, ScanGauge, Pioneer Appradio, Banks Technicooler and intake w/Zoodad, Dieselsite coolant filter (w/RMI-25), braided 4x4 lines, Mag-Hytec trans pan & diff covers, Fumoto oil valve (Motorcraft 15W-40), Knurled HFCM drain plug, Britebox, EZ-Down tailgate, BedStep, MBRP 5" cat-back (6" tip), Putnam class V hitch with 1upUSA bike rack, TransferFlow 30 gal toolbox tank + 46 gal midship tank = 76 gals total with Stanadyne Performance additive and FPPF cetane improver... the rest is all stock you nig-nogs. 64k miles, 1600+ hours.
Waiting for "BigTurbo" to help me install: Dieselsite Trans filter kit.
ljr869 is offline
Old 06-02-2008, 04:55 PM   #3 (permalink)
Is the path thru my engine to the exhaust or straight out the exhaust pipe?
Also, why does it leak to a certain level, then stop leaking?
I have the 6.0 "bible" & looked at a good post to a service manual.
04 F250 6.0 FX4 CC
BRUMFIJW is offline
Old 06-02-2008, 07:11 PM   #4 (permalink)
the egr cooler is a coonection between exhaust and coolant. It can let it go into cylinders via EGR valve when it is open and give white smoke but it can also leak inside cooler and run backwards through the RH exh up-pipe and then down to muffler.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.30 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 foot double tandem axle flatbed trailer.
36 foot Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
jimmy is offline
