Coolant Level Varies - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 07-09-2010, 01:04 PM Thread Starter
Can anyone explain why the COLD coolant level will vary on different days from an inch or so below the MIN mark to between MIN and MAX level even when the truck is level when checking? Where is it going? One would assume the radiator and connecting hoses would be constantly filled.
Should I add coolant and distilled water to bring it to at least the MIN level?
Thanks in advance for your input.
06 F-350 PSD Auto DRW 4x2 SB 4.3
DieselSite Coolant Filter
Edge CS gauge with EGT Probe
Blue spring installed
Reese Class V hitch with extension
05 Lance Max 881 Camper, Happijac tiedown system with Torq-Lift Fastguns
Circle J Outback Plus 2 horse trailer
Registered Appendix quarter horse, Dun colored, ridden with an Australian saddle.
jvita is offline
post #2 of 7 (permalink) Old 07-09-2010, 01:25 PM
Feedback Score: 2 reviews
I think most would say to keep it on the min level or the middle mark never to the full mark . If you have to add use only the Ford Gold coolent. Have you installed your coolent filter yet to remove the casting sand that is a problem with this motor, just a heads up.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
post #3 of 7 (permalink) Old 07-09-2010, 03:18 PM
OT
OT's Avatar
Noticed mine doing same long ago, goes up/down. Why, I don't know. I made mark little below min. mark, but it's never dropped below that. Noticed same on recent 2K+ mi. towing trip, but never went below mark I made. Does seem kinda odd, but so far no make up coolant needed (which is really good)
03 F250 XLT SC/SB 4X4 6L (stock) TqS. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
post #4 of 7 (permalink) Old 07-10-2010, 08:23 PM Thread Starter
2 stroker
Yes I have installed it, but have yet to remove and replace the filter and take it apart. I added 50-50 coolant/distilled H2O to compensate for the coolant in the filter. I just can't understand why the level varies if the radiator and hoses are full of coolant.
jvita is offline
post #5 of 7 (permalink) Old 07-10-2010, 08:47 PM
It must have to do with expansion due to heat or something. Mine doesn't loose coolant, but it seems it depends on how hot the engine is or when it got shut off. Definately hard to check the coolant or oil while filling her with fuel.
06 F-250 x/c 4X4 sb 17" alloy wheels. Tri-fold tonneau cover, weathertech vent visor,Ford floormats and splash guards. HarleyD headlights, Duplicolor bedliner coated bumpers, 08 rear bumper and taillights, herculiner rocker panels, XM radio, bosch wipers, Recon smoked cab lights, Edge Insight w/EGT probe, winter front.
06/10 ARP studs, turbo back silverline, new head gaskets, new oil cooler, upgraded turbo drain, fuel pressure reg upgrade, coolant filter, high idle mod, harpoon mod, pre-pump spin on fuel filter,ELC coolant, 6.4 banjo bolts, CCV reroute.
Truck weight empty fueled up, 4440 Front, 3040 rear, 7480 gross. Hex VXCF4,
SCT w/customs tunes from Vivian at Quick Tricks and Matt @ gearhead
worldwide73 is offline
post #6 of 7 (permalink) Old 07-10-2010, 10:28 PM
Cold level is ambient temp, not after a few hours. On a hot day this may take 4, 6 or more hours to return to ambient. Best thing is over night when the outside temp is as low as possible. One inch below the MIN line is right. This will bring you up to the Max line after a long hard uphill pull on a hot day. Very important, check cap for proper pressure holding capacity. It is cheaper to just go buy one then check it.
'06 F250 Crewcab King Ranch 4X4 auto Black 6.0 stolen 12/31/14
by clifford bledsoe.
'09 Cameo 5thwheel home while working
'02 Eddie Expedition
'91 F250 SuperCab 4X4 Stock IDI 2 tone brown E4OD
'96 IH 7.3 4700LP field mechanic
'84 Bronco II 2.8 4 speed 4X4
'50 F-1 V8 Flathead 4-speed non syncro(bought new)
'76 Honda 250 Multi Sport(enduro)
'76 F250 4x4 standard 360 Highboy
mont91 is offline
post #7 of 7 (permalink) Old 07-11-2010, 12:46 PM Thread Starter
Yes you are right. Wrong choice of words as I live in Phoenix and it is NEVER cold. Overnight ambient temperature was 85 degrees F. last night.
My question was why does it vary. I am starting to conclude that it is expansion due to elevated temperature at shutdown and it doesn't drain back into the system as the coolant cools. Therefore it should never be above the MAX line after a long, hot tow through mountains, which I did yesterday.
Opinions are welcome
jvita is offline
