coolant levels
Had oil cooler replaced to cure the puking coolant issue, so far so good. Been checking coolant level much more lately. Coolant is higher in bottle when cold than when hot. Is that correct? I kinda thought it would be the other way around.
Doug
2007 F-350 Crew Cab DRW 4X4 4.10LS, MBRP 4" Cool Duals turbo back, SCT/ custom tunes from Elite Diesel, Autometer gauges EGT, Trans, Fuel Pressure, MSD Dash hawk OBD II reader for ECT,EOT,Voltage and Boost, Dieselsite coolant filter
