Anyone experience Coolant overflow in UNMODIFIED 05 (or other years). Went in for first oil change and noticed radiator overflow cap encrusted.[img]/ubbthreads/images/graemlins/confused.gif[/img] Truck is daily driver and not subject to long distance or heavy towing. All towing short distances, reasonable speeds and loads well within manufacturer's limits.
Ideas?
Also, some confusion at the dealership - one tech excited to tear it down and repace a head gasket - another believed capy may not have been tight or there was other problem, without mention of any such "teardown". I am not thrilled about the thought of a dealship tech tearing down a new 6.0 - think new long block more properly in order.
Yes I had the same thing happen with my unmodded 6.0 My coolant was well above the max mark on the tank .I took out about a quart and I havn't noticed it since.
2005 F-250 CC S.B. 6.0 AUTO 4x4. SOLD 2011 F-250 CC S.B. 6.7 AUTO 4x4
Thanks - see my additions to the original post - Scary!! [img]/ubbthreads/images/graemlins/eek.gif[/img]
P.S. - Exact Same Truck - 05 SD CC SB 4X4 April Build
2005 F250 Lariat-loaded 6.0 CC SB 4X4 04/05 build sprayed BL, otherwise Bone Stock
2001 Ex Ltd 7.3 4X4 08/01 build - prelube/post lube pump - otherwise Bone Stock
{Retired} 1999 V10 - 250XLT 08/98 build - Bone Stock - Sold in 01 to switch to X -
1993 GT 5.0 - Original Owner - daily driver at 105K; suspensiton upgrades; powertrain bone stock (and a better record of staying out of the shop over 13 years than the F250).
Most be an april thang. Mine had the crusty but no leaks. Seems like it was overfilled at factory. Drained some out and havn't had a problem since. Mine is pushed to the limits towing and never puked once. Great truck Don't sweet it seems like alot of them that month were overfilled.If it pukes it then I would worry.
O5 F-250 SuperDuty CC SWR 4x4 Lariat
8' box 6.0 PSD Tow Comand new 04/05
2001 40' Alfa Toyhouse
Pulls better stock than my 01 with a programmer
New engine at 42k . Hope my luck with this 6.0 is changed .
This is called "puking" and in some cases means the head gaskets have started to leak. With that being said, I would wait to see if it does it again and if it does have them replace the cap and wait. If it continues to do it then have the dealer test the coolant for hydrocarbons. If they are present then you will need to consider letting them do the gaskets or egr cooler. If all you are seeing were a little crust or a drop of two then I would not worry about it but if you see little white dots all over the place then I would get them to test the coolant. It is commonly believed the degas bottle is extremely undersized for the coolant system on this truck so a little overflow is normal until the system equalizes its desired level in the bottle.
Thanks for those0 who have responded. My guess - "Rock Doctor" has some experience with this - a tech with a lot of experience an engineer?
While initially frustrated, I have learned the following.
A. The Puking definition has come in to be the best "web search" criteria to give me knowledge - which is what I was seeking in the first place - as that is true POWER; and
B. Here's what I have learned in this endeavor:
1. The overflow resevoir contains a minimal capacity - some complain - BUT may be designed "idiot indicator" - SEE BELOW!
2. Modified and not properly monitored modifications can result in - PUKING - maybe a result of self-induced problems - as with Gas - you overheat the powerplant - you score pistons - warp heads - and do untoward damage to parts from your "lack of knowledge" - I have been there - and it sucks.
3. Nonmodified engines that are abused PUKE - l;ike excessive ideling in hot temperatures - a gas modor would have cooked the oil - thanfully you have 3X the capacity - agin another "redeeming quality" of a diesel
4.Some PSD's have out of tolerance (intake - head)parts - whether self-induced or manufactured - that causes heads to not properly seal - Result : it "PUKES" as a result of a gasket leak
<font color="red"> </font> The fortunate thing about the little coolant resevoir - of any of 2-4 apply any idiot under the hood will see it and say - "somthing's up I better get this checked out!"
MORAL: Before you detrmine how to react and respond to postings thing about the following
If you are in this site - you
(a) love your FORD diesel,
(b) are interested in one - but want to learn more,
(c) are frustrated about it, or
(d) looking to entertain yourself at the expense of someone else - by messing with those in the (b) or (c) category - and receiving a response from someone in the (a) category.
Thanks to those of you who post constructive messages.
[img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Keep it up and ignore the (d) categories here. If you want to play their game - go to their comparable site and flame them there! [img]/ubbthreads/images/graemlins/cool.gif[/img]
To destroy your enemy you must - kown them, understand them, and use their own flaws to destroy them. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Age, knowledge, and trechery overcome youth, strength and exuberance every time!! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Rock Dock is spot on with his info. I have an '06 that was getting the crusties when it was just a few weeks old (bone stock). The degas bottle was filled from the factory to a point somewhat above the "full hot" mark. I drew it down to where it is at the "full cold" when at normal operating temp. and it hasn't done it since. I also agree that the bottle is too small for the application. Good luck! ---- What a terrible thing to have to say to someone with a new truck [img]/ubbthreads/images/graemlins/tongue.gif[/img]
The results are in - <font color="red"> </font> HEAD SURGERY <font color="black"> </font> [img]/ubbthreads/images/graemlins/eek.gif[/img] Initially they say head gaskets. I am going to lean on them to have the heads checked for tolerances - as it doesn't seem that a properly installed head gasket would leak without there being some problem with the metals on either side of it.
Three weeks of disaster.
[img]/ubbthreads/images/graemlins/sick.gif[/img] No ride, no rental without factory ESP and a lovely payment.
The heads are probably fine. If you have ever seen the new style gaskets that are installed on many engines today, you would be amazed. The 6.0L is no exception. The head gaskets are a multi-layered steel gasket with printed sealant on the surfaces and presumably between the layers as well. <font color="#FF0000">Once the "seal" has been breeched by over pressurizing the cylinders </font>, the leak only gets worse. Even a slight leak during occasional heavy load operation will eventually worsen. The official repair is to replace the head gaskets and the head bolts. The gaskets have been redesigned to seal better. The bolts are the same original design and are not the problem. The reason for replacing the bolts is that a torque to yield bolt can only be used once. As for the cylinder heads, as long as they are within the allowed tolerances for cylinder head straightness and flatness, they are good to return to service.
<font color="red"> Once the "seal" has been breeched by over pressurizing the cylinders... </font>
This is typically caused by an over boost condition due to a sensor and turbo malfunction or more commonly, aftermarket performance enhancers. Therefore, replacing the head gaskets is only half of the repair. The cause of the over boost condition needs to be identified and corrected.
__________________ . Ford Master Diesel Technician Diesel Technician Society Diesel Mentor Directory
Well fortunately I know better than to place "aftermarket mods" on this truck. Have heard the horror stories and will not make that mistake.
Hopefully they can get it fixed correctly the first time.
Love the trusck - better handling than the older models and musch more power that the 7.3.
I just read this thread. I noticed a lot of little white spots on my engine when I took it in for the fraying belt a few days after I took delivery. I wasn't sure what they were and the mechanic said he didn't know either. Could these be coolant?
2005 F-250 King Ranch Crew Cab.
