coolant puke issue? new head gasket(s) needed?
I've read several threads and the answers seem to all be there. Thanks. I guess I just needed my own thread before I see the SA.
- '03 6.0, 55K miles, no chip
- traveling uphilll @ ~55mph coolant smell thru heater vents (3x in the past couple of months, once pulling 2 ATVs)
- loss of heat @ idle
- coolant level so low there is none in reservoir (can I add the yellow if I don't know which kind was stock? I have no idea how much I'll need to add to bring it to minimum)
- white spots of coolant puke concentrated in/around the fan assembly, on the shrouds, and blown all over the engine (interestingly, there were spatterings of the same kind of puke spots all over the engine when I took delivery @ 52 mi. on odo.)
? Does this sound like a classic case of the common coolant puke/head gasket issue?
? What runarounds, if any, should I avoid to streamline the whole process of getting it diagnosed CORRECTLY and getting it repaired? (i.e. should I ask them to perform a cylinder compression test at the initial diagnosis, when they attempt to bandaid the situation by replacing the degasser tank? etc)
? How long - start to completion - has this whole process taken others here?
? I am inside of 5yr/100K mi, so this will cost $100 only, right?
? I have seen posts about the preference of using ARP head studs. Is this something that shops are willing to use, or is this a case by case thing? or is it even necessary w/ improved Ford parts now?
? Would the 13pt Extended Service Plan cover this if it were to happen again later on?
Any other advice/knowledge/wisdom is greatly appreciated.
Thanks a million. The info you all contribute is truly appreciated. Happy Holidays to you all.
Neil
2003.5 F350 4x4 CC Lariat, 6.0 Auto, Solid Black, Leather, 40/20/40, Loaded. Ordered 1/29/03, Built week of 2/24/03, Delivered 3/14/03
Added: B&W Turnover Hitch, Line-X Liner, Magnum bug deflector, chrome winks, Husky liners, Prodigy brake controller, warranty work @24K mi 10/05: new EGR, EBP, ICP, 4 injectors, fuel tank (leak), 1st flash
