Coolant temp what is too high? - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 03-19-2017, 12:15 AM Thread Starter
Looking to set limits on my H&s Mini max tunner was wondering what a good top number would be for the coolant. In other words what temp does the danger zone start so i can set it below that.
2003 FORD 6.0 H&S Mini Max Tuner, Aurora 3000 turbo, 4 inch turbo back exhaust, Hot FICM, Fass 125gph system, Cold air intake, Over sized intercooler pipes, modified intake elbow, 3" lift 35 inch tires.
jim hawkins is offline
post #2 of 4 (permalink) Old 03-19-2017, 03:35 PM
The PCM will defuel from stock fuel levels at 253 degrees F. So set your Defuel on minimax below that
2001 Ford F250 4x4 CrewCab 7.3 Automatic, 4 inch MBRP exhaust, Diablosport Predator, Edge evolution (monitor only), Cold Air intake,
Andrew Hubert is offline
post #3 of 4 (permalink) Old 03-19-2017, 08:08 PM
The 253 *F number is the oil temp defuel point.
The coolant defuel point is 221 *F.
Mark
bismic is online now
post #4 of 4 (permalink) Old 03-20-2017, 06:34 AM
meteor56's Avatar
My MiniMax defuel is set at 220, vs. the PCM's 221.
meteor56 is offline
