Old 11-06-2009, 09:11 AM   #1 (permalink)
dmausel's Avatar
Cooling fan
With the hood up, I can see the cooling fan spinning on cold start ups and it spins constantly I think. The heat/ac is off. It's not spinning very fast and roaring like it does on hot days under heavy load or with the AC on. Is this normal? Thanks, Dave
2006 F250 6.0 (2005 engine build date), white XL regular cab, 6 spd manual, towing package, gooseneck hitch, long bed, 63,000 miles, FX4, spray in bed liner, BFG's, mudflaps, precision fit bench seatcover, superduty floor mats, sirius CD player, stock except for a silly K and N filter from the previous owner.
1985 Terry Taurus 23'
1967 Avion c-10 slide-in camper
Service since 32,000 miles
1 EGR valve
1 Fuel pump
1 Ball joint
1 one anti-lock brake sensor
2 Cam position sensor leaks
1 Transfer case leak
1 power steering fluid seep from a hose
dmausel is offline
Old 11-12-2009, 07:16 PM   #2 (permalink)
dmausel's Avatar
found the answer burried in another thread
Originally Posted by AutoJim View Post
The fan always *turns*, but the fan drive only engages when needed. On warm/hot days with the AC on, it'll engage (at least partially) at stoplights, and when the light changes and you pull away, there's a bit of "flare" that makes some noise until the fan drive can pump out.
Normal stuff. You try to make a 26" fan with a roughly 3" pitch quiet above 1500 rpm or so, without compromising airflow. If you can, let me know and I'll put you in touch with the supplier, who will probably pay you for the patent rights...
sweet
1 EGR valve
1 Fuel pump
1 Ball joint
dmausel is offline
