Cracked Head cause? - Diesel Forum - TheDieselStop.com
Old 07-15-2009, 01:29 AM   #1 (permalink)
Cracked Head cause?
My 05 F550 service truck likely has a cracked head. If so what are the most common causes? Most engines will not tolerate low coolant levels, if the fire deck is not covered with coolant, BAM, cracked head.
What I'm wondering is I had the coolant changed a few days prior to the fuel in the cooling system showing up. How tricky are these to get the air purged out of? Could this be the cause?
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 07-16-2009, 08:05 PM   #2 (permalink)
Cmon guys, 70+ views and no one had an opinion? Please comment....
Old 07-16-2009, 08:24 PM   #3 (permalink)
RatherBNtheWoods's Avatar
I don't think it's tricky at all. At least not in the(my) 350 truck. Mine has been changed iirc 3 times now, twice by dealer techs doing warranty work and once by me. Seems you fill'er up, run'er a bit, check the level and your done.
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 55 gal aux fuel tank. A real pig from a stop, give me 15' and she'll slowly come to life, then watch out!
165K miles, 12 injectors, EGR cooler, Fuel pump, 8 glow plugs, GPCM, FICM rebuilt FoMoCo engine at 150K under 7/200 warranty.
RatherBNtheWoods is offline
Old 07-17-2009, 02:42 AM   #4 (permalink)
The cause is a bad design care of Navistar (not Ford). There is no legit cause for cracked heads, they just happen.
I'm a mod friendly Ford Diesel Technician located in Sacramento California area.
Gofaster23 is offline
