Cracked y-pipe...mechanic (not dealer) in Tacoma/Seattle? - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 08-26-2009, 11:06 AM Thread Starter
Well, while attempting to remove my downpipe to access the EGR cooler flange, I believe I've cracked my y-pipe bellows. I have all the symptoms...exhaust in cab, whistle under hood, low boost, high EGT, etc...
Anyway, it's out of warranty, and I'm not going to take it to a dealer, so does anyone know of a good performance shop around the Tacoma area I caould take it to? While they're replacing the y-pipe, I'd like them to install a delete on something else that's under there as well...
Got a coolant smell when towing problem (again) and hoping removing something will keep it from happening if it hasn't already ruined the headgaskets again (already had new headgaskets 30k ago).
Anyway, I've got to keep this truck for a while, so just want to find a reliable mod-friendly mechanic who knows the 6.0 problems and has the experience to fix them.
Thanks in advance.
2003 F250 Lariat CC SRW 4X4, 6.0, Auto
dacunn is offline
post #2 of 4 (permalink) Old 08-26-2009, 04:58 PM
I learned a little trick for the 6 liter Y pipe. After removal it twangs and doesnt fit the same. I found once the clamp is around the rear of the turbo, if you take a long 2 inch pipe and bang on the clamp it will usually go back into place. Sometimes you may need to loosen the flange bolts at the manifold but only as a last resort. Its worth a try.
1999 F250 2WD RC/LB posi AIS, Superchips DPI propane, 4" turboback exhaust, gauges, Edge Evolution tuner [looking into a Propane chip]
SMOKESKULL is offline
post #3 of 4 (permalink) Old 08-26-2009, 05:48 PM
hottip's Avatar
Go to Stans Custom Headers in Auburn or the Power shop in Enumclaw. Stans does exhaust work and the Power Shop can do everything that you want. They did my Banks upgrades and are reasonably priced.
2005 Lariat 6.0 LWB fourx4 3:73 Silver Metalic, Heated Captains chairs, Tow Command, Reverse Sensor, Intergrated Brake Control, Power Rear Window
MBRP Turbo back exhaust, Glasstite Canopy, billet grill, 162+
Scan Gauge 2
Bear - Flat Coated Retriever
2000 HD Road King
1998 Campion 542 Explorer fishing machine
The difference between stupidity and genius is that genius has its limits.
hottip is offline
post #4 of 4 (permalink) Old 08-26-2009, 10:29 PM Thread Starter
Thanks guys, I also found Boyers truck in Orting while I was waiting for replies. I'll call Stan's and the Power Shop tomorrow...
dacunn is offline
