Creeking when steering, horrid sound! - Diesel Forum - TheDieselStop.com
Old 11-11-2009, 12:37 PM   #1 (permalink)
conifers4's Avatar
Unhappy Creeking when steering, horrid sound!
There is a horrible creeking/whining sound when I turn my steering wheel in either direction. The sound is coming from the steering box I believe. Is there something inside that needs to be lubricated because thats exactly what it sounds like. Could the steering box just be bad, the truck only has 46K on it and does not go off road.
2003 F-250 6.0 Lund visor, vent visors, Sirius satellite, diamond tread toolbox, smoked cab lights, bedliner, Galaxy DX959 CB, Wilson 5000 antenna, Turner Road King 56 mic
conifers4 is offline
Old 11-11-2009, 01:46 PM   #2 (permalink)
I would lean more towards a Bad Ball Joint.They will make the exact sound you describe.These tks are classic for that problem.One of them is probabley siezeing up.
07,F-250 4X4 6.0 Torqshift, Lariat, Highline package, S/C LWB.
grounder is offline
Old 11-11-2009, 04:01 PM   #3 (permalink)
find all you zirc fittings under the front end of you truck and pump them full of grease. Mine was doing this same exact thing, i though it was the worm gear in the steering box, but i greased it all up and i still have had no trouble
early 1999, 7/98, F-250 7.3L, 250,000+ miles, 4x4, triple disk torque convertor, AFE dryflo home made cold air intake, straight pipe exhaust, superchips tuner (stuck on high performance tune,because someone stole the tuner out of my truck), 4.7K mod, Glow shift gauges (pyro, boost, egt), CCV mod, 3in of lift in front, 1in in back w/ 2009 SD rims w/ 2in wheel spacers wrapped in 325/65/18 Fierce Attitude MT, aftermarket headlamps w/ LED's, ranchhand grill guard, 03' front bumper w/ fog lights, gooseneck hitch
browningbuck225 is offline
Old 11-11-2009, 05:09 PM   #4 (permalink)
LoneStarDiesel's Avatar
It could be something in the steering linkage. Check your ball joints, tie rod ends any bushings etc. These heavy trucks are put under a lot of force
turning.
03 F250 4 door 4x4 6.0
LoneStarDiesel is offline
Old 11-11-2009, 05:53 PM   #5 (permalink)
Supporting Member
my03psd's Avatar
I agree.
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
Old 11-11-2009, 08:10 PM   #6 (permalink)
69cj's Avatar
you must have a diff. truck than me. No zerks where it counts. 05 SD.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 11-11-2009, 08:53 PM   #7 (permalink)
fordsforever73's Avatar
My Photos: (21)
Feedback Score: 2 reviews
I'd put money on ball joints too. Good time to replace them and the u-joints (if it's a 4x4) with greaseable stuff.
05 F-350 Crewcab 4x4, 6.0, Auto, Dually, My new Tow Rig
95 F-350 Crewcab 4x4, 7.3, Auto, Awesome Tow Rig...Sold on May 17/09 (went to a good home)
80 F-250 4X4, 429, 4 Speed, Lifted, Solid Axles, Boggers, 450,000km and going strong...Gonna Go
90 Bronco, Work in Progress
fordsforever73 is offline
Old 11-11-2009, 11:08 PM   #8 (permalink)
yea i do i have an early 99' but there are NO zirc fittings under your front end?
Old 11-12-2009, 07:23 PM   #9 (permalink)
Ditto; Ball Joint (s) Been There,Done That twice.
'04 F350SC Lariat sb cx 6.0 auto 4x4
'01 Exc. Ltd fu 7.3 4x4
'00 FLHTCUI sinister
'96 WX3 bbb
TwiceStroked is offline
Old 11-13-2009, 11:21 AM   #10 (permalink)
conifers4's Avatar
Thanks for the replies! After talking with a friend of mine I was told that if I continue to drive with bad ball joints they will eventually freeze up causing the steering system to lock in place. Sounds wonderful, so I better bring the truck in asap. I have a feeling the bill is going to hurt
Old 11-13-2009, 12:26 PM   #11 (permalink)
69cj's Avatar
Take it to a private front end shop and get a/m greasable joints that will last a lot longer if you keep grease in them.
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
