Cruise Control Sticking???? - Diesel Forum - TheDieselStop.com
Old 05-19-2005, 01:33 AM   #1 (permalink)
Cruise control is not working properly. Today I turned it on while on the Parkway, then when to shut it off by braking so I would not his the car and found myself braking harder and harder.
It did not shut off when I hit brake and accually tryed to speed up. But after a few seconds of pushing brake it will go off.
What the heck is going on with it? Anyone else have problems with that?
I ran 2 power cables up the passengerside rocker channel and behind the pass. kickplate. Is there anything related to the cruise control in those locations that I could have interfered with it. Don't remember or think I hit anything.
Also got trans. recall done about 4 days prior to this, and don't think I have used cruise since then. Could that have affected it? Where should I look to see if any wires are lose for cruise?
2004 F-250 Oxford White/Silver XLT FX4 4x4 SC/LB
6.0 Powerstroke 3.73s
Scotto2323 is offline
Old 05-19-2005, 03:30 AM   #2 (permalink)
Banned
Re: Cruise Control Sticking????
Check to be sure your brake lights are working.
GrampyJim is offline
Old 05-19-2005, 10:33 AM   #3 (permalink)
Mine was doing the exact same thing after I installed XM radio??????
I am overseas right now, my Brother-in-law has the truck and he said the cruise control is working normally. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
04 F-250 Lariat FX4 SC
jetratt is offline
Old 05-19-2005, 07:23 PM   #4 (permalink)
Mine was doing same thing. It was intermittant and took spells of working or not working. Brake lights were working just fine.
Mine was so bad that I could gradually push the brakes and it would start to downshift before finally disengaging the cruise.
The brake (pedal) switch has a circuit that normally will disengage the cruise; if it fails there is a pressure switch on the master cylinder that will disengage the cruise. (remember those switches on the F-150's that were recalled for causing fires!) What is probably happening is your brake switch (on the brake pedal) is faulty; that is what was my problem. I'm glad Ford has the pressure switch as a back-up. Mine was fixed under warranty back in February.
Good luck with your problem.
Bob
08 F350 DRW 4x4 Lariat CC 6.4 torqshift wide track front axle 4.10LS
07 Montego Bay 34RLB3 5th wheel
(traded the 04 w/ 56K mi. on 3/25/06; the 06 w/ 45K on 10/1/07)
bnmccoy is offline
Old 05-20-2005, 09:33 PM   #5 (permalink)
Ok, I accidently pulled a hose off under dash pass. side. Air came out and I heard a popping sound. Sounded like somthing with a Heating/AC like when you switch the vents.
Was this what I did, or is that involved with the cruise control?
